Exception while running web sphere workbench 2.0 [message #17175] |
Tue, 13 August 2002 07:29  |
Originally posted by: asifjaan.yahoo.com
hi
This might not be a perfect question for the forum
I am using IBM webspehere workbench 2.0 on windows and am working with IBM
Schema Set Info set API
when ever i run any Java programme i get following exception
can anyone help about the configuration , this file is there in the
directory.
Is there any setting that i have to change in order for it to work
properly and not throw any exception ..
The workbench works well , but throws the exception when ever i run it
thanks
java.io.FileNotFoundException:
file:///eclipse/plugins/com.ibm.etools.xsd/plugin.properties (The
filename, directory name, or volume label syntax is incorrect)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:78)
at com.ibm.etools.xsd.XSDPlugin.getString(XSDPlugin.java:100)
at com.ibm.etools.xsd.XSDPlugin.getString(XSDPlugin.java:126)
com.ibm.etools.xsd.impl.XSDSimpleTypeDefinitionImpl$Assessme ntImpl.validate(XSDSimpleTypeDefinitionImpl.java:3120)
com.ibm.etools.xsd.impl.XSDSimpleTypeDefinitionImpl.assess(X SDSimpleTypeDefinitionImpl.java:3355)
com.ibm.etools.xsd.impl.XSDSimpleTypeDefinitionImpl.getValue (XSDSimpleTypeDefinitionImpl.java:3370)
com.ibm.etools.xsd.impl.XSDEnumerationFacetImpl.analyze(XSDE numerationFacetImpl.java:372)
com.ibm.etools.xsd.impl.XSDConcreteComponentImpl.analyze(XSD ConcreteComponentImpl.java(Compiled
Code))
com.ibm.etools.xsd.impl.XSDTypeDefinitionImpl.handleAnalysis (XSDTypeDefinitionImpl.java:319)
com.ibm.etools.xsd.impl.XSDSimpleTypeDefinitionImpl.handleAn alysis(XSDSimpleTypeDefinitionImpl.java:935)
com.ibm.etools.xsd.impl.XSDTypeDefinitionImpl.analyze(XSDTyp eDefinitionImpl.java:292)
Code))
at com.ibm.etools.xsd.impl.XSDFeatureImpl.analyze(XSDFeatureImp l.java:480)
com.ibm.etools.xsd.impl.XSDAttributeDeclarationImpl.analyze( XSDAttributeDeclarationImpl.java:292)
Code))
com.ibm.etools.xsd.impl.XSDAttributeUseImpl.analyze(XSDAttri buteUseImpl.java:1192)
Code))
com.ibm.etools.xsd.impl.XSDComplexTypeDefinitionImpl.handleA nalysis(XSDComplexTypeDefinitionImpl.java:1198)
Code))
com.ibm.etools.xsd.impl.XSDElementDeclarationImpl.handleAnal ysis(XSDElementDeclarationImpl.java:645)
com.ibm.etools.xsd.impl.XSDElementDeclarationImpl.analyze(XS DElementDeclarationImpl.java:593)
Code))
Code))
Code))
com.ibm.etools.xsd.impl.XSDConcreteComponentImpl.analyze(XSD ConcreteComponentImpl.java:493)
at com.ibm.etools.xsd.impl.XSDSchemaImpl.analyze(XSDSchemaImpl. java:1518)
at com.ibm.etools.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.ja va:1505)
com.ibm.etools.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSch emaImpl.java:2023)
com.ibm.etools.xsd.impl.XSDConcreteComponentImpl.internalNot ify(XSDConcreteComponentImpl.java(Compiled
Code))
com.ibm.etools.emf.notify.impl.NotifierImpl.notify(NotifierI mpl.java(Compiled
Code))
com.ibm.etools.emf.ref.impl.RefObjectImpl.refSetValueForSimp leSF(RefObjectImpl.java(Compiled
Code))
Code))
com.ibm.etools.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDS chemaImpl.java:785)
com.ibm.etools.xsd.util.XSDResourceImpl.setResourceSet(XSDRe sourceImpl.java:108)
com.ibm.etools.emf.resource.impl.ResourceSetImpl.basicAdd(Re sourceSetImpl.java:61)
com.ibm.etools.emf.resource.impl.ResourceSetImpl.add(Resourc eSetImpl.java:40)
com.ibm.etools.emf.resource.impl.ResourceSetImpl.processNewR esource(ResourceSetImpl.java:377)
com.ibm.etools.emf.resource.impl.ResourceSetImpl.load(Resour ceSetImpl.java:313)
com.ibm.etools.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSD SchemaImpl.java:534)
com.ibm.etools.xsd.impl.XSDSchemaImpl.createSchema(XSDSchema Impl.java:348)
com.ibm.etools.xsd.util.XSDResourceFactoryImpl.load(XSDResou rceFactoryImpl.java:178)
com.ibm.etools.emf.resource.impl.ResourceFactoryImpl.load(Re sourceFactoryImpl.java:89)
com.ibm.etools.emf.resource.impl.ResourceFactoryImpl.load(Re sourceFactoryImpl.java:77)
com.ibm.etools.emf.resource.impl.ResourceSetImpl.load(Resour ceSetImpl.java:289)
at mapper.MapperMain.analyseSchema(MapperMain.java:71)
at mapper.MapperMain.main(MapperMain.java:182)
FUDForum. Page generated in 0.04632 seconds
