Home » Archived » XML Schema Definition (XSD) » Access to XML header properties: How?
Access to XML header properties: How? [message #17154] Tue, 08 April 2003 03:23 Go to next message
Originally posted by: dirk.schesmer.divos.de
Hi all,
being from Europe, I'd like to specify the following XML header using
ISO-8859-1 encoding for my XML schemas: <?xml version="1.0"
encoding="ISO-8859-1"?>
Can someone please show me the corresponding Java statements?
Thanks for help,
Dirk V. Schesmer
Re: Access to XML header properties: How? [message #17184 is a reply to message #17154] Tue, 08 April 2003 19:01 Go to previous messageGo to next message
Dirk,
Being from the center of the universe, I did not consider how to do
this. (Actually I was born in Europe, and Canada is hardly the center of
the universe. ;-) Clearly this capability needs to be supported, so I
will consider how best to do that and get back to you with a solution as
soon as possible. I'll probably provide support for access to
XSDResourceImpl.getDefaultSaveOptions() and support an XSD_ENCODING
option. The default save option will be set if and when the .xsd is
loaded and can then be overriden directly or by passing an option in
during save...
"Dirk V. Schesmer" wrote:
> Hi all,
> Thanks for help,
> Dirk V. Schesmer
Re: Access to XML header properties: How? [message #17210 is a reply to message #17184] Wed, 09 April 2003 13:44 Go to previous messageGo to next message
--------------480F7E616724870EFDB49D62
Content-Type: text/plain; charset=us-ascii
Dirk,
I was hoping to be able to detect the encoding when reading a document but
this Xerces FAQ answer for how to do that
http://xml.apache.org/xerces2-j/faq-general.html#faq-5
doesn't work for the version of Xerces being used in Eclipse. :-(
When we switch to a version where it works, the resource will determine the
encoding during load and will use it during save. Until that time, you will
need to manually specify the encoding used during save. There will be two
ways to do this. Either do it as an override during each save:
Map map = new HashMap();
map.put(XSDResourceImpl.XSD_ENCODING, "ISO-8859-1");
xsdSchema.eResource().save(out, map);
or set it as the default so that it happens for every subsequent save:
// This only needs to be done once
((XSDResourceImpl)xsdSchema.eResource()).getDefaultSaveOptio ns().put(XSDResourceImpl.XSD_ENCODING,
"ISO-8859-1");
xsdSchema.eResource().save(out, null);
If the XML parser we use could detect the encoding, then the option would be
set during load...
I'm hoping to get a 1.1.0 driver out this week, but it may not be until next
week...
Ed Merks wrote:
> Dirk,
> during save...
> > Hi all,
> > Thanks for help,
> > Dirk V. Schesmer
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Dirk,
<p>I was hoping to be able to detect the encoding when reading a document
but this Xerces FAQ answer for how to do that
<blockquote><a href="http://xml.apache.org/xerces2-j/faq-general.html#faq-5">http://xml.apache.org/xerces2-j/faq-general.html#faq-5</a></blockquote>
doesn't work for the version of Xerces being used in Eclipse.&nbsp;&nbsp;
<p>When we switch to a version where it works, the resource will determine
the encoding during load and will use it during save.&nbsp; Until that
time, you will need to manually specify the encoding used during save.&nbsp;
There will be two ways to do this.&nbsp; Either do it as an override during
each save:
<blockquote>Map map = new HashMap();
<br>map.put(XSDResourceImpl.XSD_ENCODING, "ISO-8859-1");
<br>xsdSchema.eResource().save(out, map);</blockquote>
<blockquote>// This only needs to be done once
<br> ((XSDResourceImpl)xsdSchema.eResource()).getDefaultSaveOptio ns().put(XSDResourceImpl.XSD_ENCODING,
"ISO-8859-1");
<br>xsdSchema.eResource().save(out, null);</blockquote>
be set during load...
<p>I'm hoping to get a 1.1.0 driver out this week, but it may not be until
next week...
<br>&nbsp;
<p>Ed Merks wrote:
<blockquote TYPE=CITE>Dirk,
<p>Being from the center of the universe, I did not consider how to do
<br>this.&nbsp; (Actually I was born in Europe, and Canada is hardly the
center of
<br>the universe. ;-)&nbsp; Clearly this capability needs to be supported,
so I
<br>will consider how best to do that and get back to you with a solution
as
<br>soon as possible.&nbsp; I'll probably provide support for access to
<br>XSDResourceImpl.getDefaultSaveOptions() and support an XSD_ENCODING
<br>option.&nbsp; The default save option will be set if and when the .xsd
is
<br>loaded and can then be overriden directly or by passing an option in
<br>during save...
<p>"Dirk V. Schesmer" wrote:
<p>> Hi all,
<br>>
<br>> being from Europe, I'd like to specify the following XML header using
<br>> ISO-8859-1 encoding for my XML schemas: &lt;?xml version="1.0"
<br>> encoding="ISO-8859-1"?>
<br>>
<br>> Can someone please show&nbsp; me the corresponding Java statements?
<br>>
<br>> Thanks for help,
<br>> Dirk V. Schesmer</blockquote>
</html>
--------------480F7E616724870EFDB49D62--
Re: Access to XML header properties: How? [message #17238 is a reply to message #17210] Wed, 09 April 2003 16:10 Go to previous messageGo to next message
--------------B9FE08DD863A262E6F64F0F1
Dirk,
With the help of Sandy Gao from the Xerces team I was able to hack out a
solution. It's not pretty, but it works. So the resource will be able
to auto detect the encoding during load and will use it during save.
Naturally when you create a new resource/schema from scratch, you'll
need to set it as outlined below...
Ed Merks wrote:
> Dirk,
> determine the encoding during load and will use it during save. Until
> that time, you will need to manually specify the encoding used during
> save. There will be two ways to do this. Either do it as an override
> during each save:
> ce()).getDefaultSaveOptions().put(XSDResourceImpl.XSD_ENCODI NG,
> "ISO-8859-1");
> would be set during load...
> until next week...
> Ed Merks wrote:
>> Dirk,
>> center of
>> I
>> solution as
>> during save...
>> > Hi all,
>> using
>> > Thanks for help,
>> > Dirk V. Schesmer
<html>
Dirk,
<p>With the help of Sandy Gao from the Xerces team I was able to hack out
a solution.&nbsp; It's not pretty, but it works.&nbsp; So the resource
will be able to auto detect the encoding during load and will use it during
save.&nbsp; Naturally when you create a new resource/schema from scratch,
you'll need to set it as outlined below...
<br>&nbsp;
each save:
"ISO-8859-1");
next week...
<br>&nbsp;
center of
so I
as
is
<br>during save...
<p>> Hi all,
<br>>
<br>>
<br>>
</blockquote>
</html>
--------------B9FE08DD863A262E6F64F0F1--
Re: Access to XML header properties: How? [message #18929 is a reply to message #17238] Thu, 01 May 2003 02:54 Go to previous messageGo to next message
Originally posted by: paechoi.earthlink.net
I see the v1.1 in the CVS, but not on the release web page. The latest is
shown as:
March 26th - Release Version 1.0.2 build (20030326_0335VL) is available for
download
When would be the date we can expect the official release of 1.1 that
support
the XSDResourceImpl.XSD_ENCODING?
Pae
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3E947E3D.CF030F24@ca.ibm.com...
Dirk,
solution. It's not pretty, but it works. So the resource will be able to
auto detect the encoding during load and will use it during save. Naturally
when you create a new resource/schema from scratch, you'll need to set it as
outlined below...
Ed Merks wrote:
Dirk,
set during load...
week...
Ed Merks wrote:
Dirk,
during save...
> Hi all,
> Thanks for help,
> Dirk V. Schesmer
Re: Access to XML header properties: How? [message #18951 is a reply to message #18929] Thu, 01 May 2003 05:43 Go to previous messageGo to next message
Pae,
If all goes well, the plan is to make it available today (and to populate CVS
with all the source code).
> shown as:
> download
> support
> Pae
> Dirk,
> outlined below...
> Ed Merks wrote:
> Dirk,
> set during load...
> week...
> Ed Merks wrote:
> Dirk,
> during save...
> > Hi all,
> > Thanks for help,
> > Dirk V. Schesmer
Re: Access to XML header properties: How? [message #19465 is a reply to message #18951] Fri, 02 May 2003 06:31 Go to previous messageGo to next message
Ed,
Thanks for sharing your plan as well as your prompt reply. I just
check [1]the web site and I am seeing it.
While I was reading the "1. New Plugins" section, I just had a
question for the statement as follows:
"The xsd2ecore plugins (org.eclipse.emf.mapping.xsd2ecore and
org.eclipse.emf.mapping.xsd2ecore.editor) have been added"
Would you clarify whether we need to get a specific version of
EMF package or those new plugins are added in the XSD package?
Thank you.
Pae
[1] http://www.eclipse.org/xsd/
news:3EB0EC2F.A43ED204@ca.ibm.com...
> Pae,
CVS
is
> > shown as:
for
> > download
> > support
> > Pae
> > Dirk,
to
Naturally
it as
> > outlined below...
> > Ed Merks wrote:
> > Dirk,
but
the
will
two
would be
> > set during load...
next
> > week...
> > Ed Merks wrote:
> > Dirk,
of
> > during save...
> > > Hi all,
> > > Thanks for help,
> > > Dirk V. Schesmer
Re: Access to XML header properties: How? [message #19509 is a reply to message #19465] Fri, 02 May 2003 06:49 Go to previous message
I found it. Please discard the inquiry related to those new plugins.
Pae
"Pae Choi" <paechoi@earthlink.net> wrote in message
news:b8thc0$g8k$1@rogue.oti.com...
> Ed,
> Thank you.
> Pae
> > Pae,
populate
> CVS
> is
> > > shown as:
available
> for
> > > download
> > > support
> > > Pae
> > > Dirk,
a
able
> to
> Naturally
> it as
> > > outlined below...
> > > Ed Merks wrote:
> > > Dirk,
> but
determine
> the
you
> will
> two
> would be
> > > set during load...
until
> next
> > > week...
> > > Ed Merks wrote:
> > > Dirk,
> of
as
> > > during save...
> > > > Hi all,
using
> > > > Thanks for help,
> > > > Dirk V. Schesmer
Re: Access to XML header properties: How? [message #567366 is a reply to message #17154] Tue, 08 April 2003 19:01 Go to previous message
Dirk,
during save...
> Hi all,
> Thanks for help,
> Dirk V. Schesmer
Re: Access to XML header properties: How? [message #567390 is a reply to message #17184] Wed, 09 April 2003 13:44 Go to previous message
Dirk,
"ISO-8859-1");
set during load...
week...
Ed Merks wrote:
> Dirk,
> during save...
> > Hi all,
> > Thanks for help,
> > Dirk V. Schesmer
<html>
Dirk,
each save:
"ISO-8859-1");
next week...
<br>&nbsp;
center of
so I
as
is
<br>during save...
<p>> Hi all,
<br>>
<br>>
<br>>
</html>
Re: Access to XML header properties: How? [message #567446 is a reply to message #17210] Wed, 09 April 2003 16:10 Go to previous message
Dirk,
Ed Merks wrote:
> Dirk,
> during each save:
> "ISO-8859-1");
> until next week...
> Ed Merks wrote:
>> Dirk,
>> center of
>> I
>> solution as
>> during save...
>> > Hi all,
>> using
>> > Thanks for help,
>> > Dirk V. Schesmer
<html>
Dirk,
<br>&nbsp;
each save:
"ISO-8859-1");
next week...
<br>&nbsp;
center of
so I
as
is
<br>during save...
<p>> Hi all,
<br>>
<br>>
<br>>
</blockquote>
</html>
Re: Access to XML header properties: How? [message #568187 is a reply to message #17238] Thu, 01 May 2003 02:54 Go to previous message
shown as:
download
support
Pae
Dirk,
outlined below...
Ed Merks wrote:
Dirk,
set during load...
week...
Ed Merks wrote:
Dirk,
during save...
> Hi all,
> Thanks for help,
> Dirk V. Schesmer
Re: Access to XML header properties: How? [message #568217 is a reply to message #18929] Thu, 01 May 2003 05:43 Go to previous message
Pae,
> shown as:
> download
> support
> Pae
> Dirk,
> outlined below...
> Ed Merks wrote:
> Dirk,
> set during load...
> week...
> Ed Merks wrote:
> Dirk,
> during save...
> > Hi all,
> > Thanks for help,
> > Dirk V. Schesmer
Re: Access to XML header properties: How? [message #568867 is a reply to message #18951] Fri, 02 May 2003 06:31 Go to previous message
Ed,
Thank you.
Pae
> Pae,
CVS
is
> > shown as:
for
> > download
> > support
> > Pae
> > Dirk,
to
Naturally
it as
> > outlined below...
> > Ed Merks wrote:
> > Dirk,
but
the
will
two
would be
> > set during load...
next
> > week...
> > Ed Merks wrote:
> > Dirk,
of
> > during save...
> > > Hi all,
> > > Thanks for help,
> > > Dirk V. Schesmer
Re: Access to XML header properties: How? [message #568908 is a reply to message #19465] Fri, 02 May 2003 06:49 Go to previous message
Pae
> Ed,
> Thank you.
> Pae
> > Pae,
populate
> CVS
> is
> > > shown as:
available
> for
> > > download
> > > support
> > > Pae
> > > Dirk,
a
able
> to
> Naturally
> it as
> > > outlined below...
> > > Ed Merks wrote:
> > > Dirk,
> but
determine
> the
you
> will
> two
> would be
> > > set during load...
until
> next
> > > week...
> > > Ed Merks wrote:
> > > Dirk,
> of
as
> > > during save...
> > > > Hi all,
using
> > > > Thanks for help,
> > > > Dirk V. Schesmer
Previous Topic:A Diagnostic Message for the Valid Schema
Next Topic:XSD v1.0.2 -- Undesired Messages
Current Time: Fri Sep 12 15:25:55 EDT 2025
Powered by FUDForum. Page generated in 0.04974 seconds
