Re: changing an ordinary folder to a source folder in a project [message #181777 is a reply to message #181774] |
Mon, 27 November 2006 09:00 |
Remy Suen Messages: 462 Registered: July 2009 |
Srikanth wrote:
> I have a folder in my project and I want to change it into a source
> folder. And the project is a Java Project. How should I do this?
If you mean for coding, just right-click on the folder in the Package
Explorer View, then Build Path -> Use as Source Folder.
If you mean how to do it using the JDT APIs, then you need to update
your IJavaProject's raw classpath.
// get your IProject
IProject project = getProject();
// create the corresponding IJavaProject
IJavaProject ijp = JavaCore.create(project);
// get the folder
IFolder folder = project.getFolder("nameOfNewSrcFolder");
// create a new source entry for it
IClasspathEntry entry = JavaCore.newSourceEntry(folder.getFullPath());
// retrieve the project's current classpath
IClasspathEntry[] entries = ijp.getRawClasspath();
// create a new array with the original entries and the new source entry
IClasspathEntry[] newEntries = new IClasspathEntry[entries.length + 1];
System.arraycopy(entries, 0, newEntries, 0, entries.length);
newEntries[newEntries.length - 1] = entry;
ijp.setRawClasspath(newEntries, new NullProgressMonitor());
That should be the general gist of it.
Rem
Re: changing an ordinary folder to a source folder in a project [message #181782 is a reply to message #181777] |
Mon, 27 November 2006 09:35 |
Thanks Rem!
I meant for coding and sorry for not specifying that in the first post. I
use Java Browsing perspective for coding and Resource perspective for
dealing with the other folders so didn't find any options when I right
clicked on the folder which I wanted to change to a source folder.
Just got addicted to Java Browsing perspective and unable to come out of
it :D
Thank you very much,
Srikanth
Re: changing an ordinary folder to a source folder in a project [message #181834 is a reply to message #181782] |
Mon, 27 November 2006 18:42 |
> Thanks Rem!
> I use Java Browsing perspective for coding and Resource perspective for
> it :D
I, too, prefer Java Browsing perspective. However, there are several
ways you can accomplish this from that perspective:
a) you can use Window > Show View... to open the Package Explorer and
make it a Fast View that is minimized when not in use.
b) You can right-click the project name and choose Properties. On the
Build Path section of the Properties you can select additional source
directories.
Hope this helps,
Eric
FUDForum. Page generated in 0.08781 seconds
