Home » Eclipse Projects » Nebula » To add tooltip for grid items
To add tooltip for grid items [message #17146] Mon, 27 November 2006 11:07 Go to next message
Originally posted by: krishna.24jan.gmail.com
Can any one suggest any possible solution to add tool tip for grid items.
Currently nebula supports tooltip for grid.I want to add tooltip for grid
items which will display its rown and column .
Can any one throw some light in this issue.
Thanks in advance
krishna
Re: To add tooltip for grid items [message #17255 is a reply to message #17146] Mon, 27 November 2006 11:26 Go to previous messageGo to next message
If you want tooltips that are specific to each cell you can do something
like:
grid.addListener(SWT.MouseMove, new Listener()
public void handleEvent(Event e)
Point p = new Point(e.x,e.y);
GridColumn col = grid.getColumn(p);
GridItem item = grid.getItem(p);
//determine if the col and item have changed from
//previous saved values (i.e. user just moving in new cell?)
grid.setToolTipText("MyToolTipText");
-Chris
krishna wrote:
> grid items which will display its rown and column .
> Thanks in advance
> krishna
Re: To add tooltip for grid items [message #17861 is a reply to message #17146] Mon, 27 November 2006 11:34 Go to previous messageGo to next message
Hi krishna,
That's better and here's the answer.
Checkout the following classes from JFace-Head:
-http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org .eclipse.jface/src/org/eclipse/jface/window/ToolTip.java
-http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org .eclipse.jface/src/org/eclipse/jface/window/DefaultToolTip.j ava
Although they are in JFace 3.3 you can use them without problems in 3.2.
The checkout the http://tom-eclipse-dev.blogspot.com/ to see how they
are used.
If you are using DefaultToolTip code looks like this:
---------------------8<---------------------
protected boolean shouldCreateToolTip(Event event) {
Point p = new Point(event.x,event.y);
GridItem gi = grid.getItem(p);
for( int i = 0; gi != null && i < grid.getColumns().length; i++ ) {
if( gi.contains(p) ) {
setText("ToolTip: " + gi.getText(i) );
return true;
return false;
I assume in the code above that Grid is working the same as SWT-Table
but Chris can tell you more. I haven't tried to run this code myself it
simply should get you started. Give it a try and report back if it works
for you.
Tom
krishna schrieb:
> Thanks in advance
> krishna
Re: To add tooltip for grid items [message #17869 is a reply to message #17255] Tue, 28 November 2006 00:02 Go to previous messageGo to next message
Dear Chris,
Thanks a lot for the info.I really appreciate the help.
But in the code u have sent we can get the mouse locations 'p'.
I want to dislay tooltip for the cells displaying its respective rows and
columns
From 'P' i can get columnNo but iam unable to get row no.
Can u help me out in this..
Thanks in advance
krishna
Re: To add tooltip for grid items [message #17896 is a reply to message #17869] Tue, 28 November 2006 03:35 Go to previous message
Wrong please reread the snippet from Chris:
------------------8<-------------------------
GridItem item = grid.getItem(p); // This is the row
Tom
krishna schrieb:
> Dear Chris,
> and columns
> Thanks in advance
> krishna
Re: To add tooltip for grid items [message #569253 is a reply to message #17146] Mon, 27 November 2006 11:26 Go to previous message
like:
-Chris
krishna wrote:
> Thanks in advance
> krishna
Re: To add tooltip for grid items [message #569332 is a reply to message #17146] Mon, 27 November 2006 11:34 Go to previous message
Hi krishna,
are used.
return true;
return false;
for you.
Tom
krishna schrieb:
> Thanks in advance
> krishna
Re: To add tooltip for grid items [message #569404 is a reply to message #17255] Tue, 28 November 2006 00:02 Go to previous message
Dear Chris,
columns
Thanks in advance
krishna
Re: To add tooltip for grid items [message #569468 is a reply to message #17869] Tue, 28 November 2006 03:35 Go to previous message
Tom
krishna schrieb:
> Dear Chris,
> and columns
> Thanks in advance
> krishna
Previous Topic:Multiple selection of items in nebula grid
Next Topic:Grid - Cell Height
Current Time: Sun Jun 01 00:04:05 EDT 2025
Powered by FUDForum. Page generated in 0.04674 seconds
