Home » Language IDEs » C / C++ IDE (CDT) » VisualC Error Parser
VisualC Error Parser [message #181714] Fri, 29 December 2006 14:58 Go to next message
I am trying to create a custom CDT Error parser for an embedded compiler. I
started by making a generic plugin project and then copying
VCErrorParser.java. If I use the VCErrorParser from Oct 2006 or earlier
(extends IErrorParser) then everything works. But if I use the
VCErrorParser from the head revions which is dramatically simplified
(extends AbstractErrorParser) then I can't get it to work. Do I need a more
recent version of CDT to get the Error Parser based on AbstractErrorParser
to work? (currently using 3.1.1)
Also, do I need an activator for this type of plugin if my only extension is
org.eclipse.cdt.core.ErrorParser?
Doug
Re: VisualC Error Parser [message #181718 is a reply to message #181714] Sat, 30 December 2006 05:04 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
The version from the HEAD is designed for CDT4.0 (release approx June 07)and is
work in progress. Suggest you stay with the version you have for CDT3.1.x
Derek
> Doug
Re: VisualC Error Parser [message #181722 is a reply to message #181714] Sat, 30 December 2006 07:04 Go to previous message
> is org.eclipse.cdt.core.ErrorParser?
Someone answered me a while back that you need the activator.
If you use the wizards it will be generated automatically, so I never really
experimented with omitting it.
tpt
Previous Topic:long delay after "Content Assist" activators
Next Topic:only /dev/ttyS0
Current Time: Wed Jul 16 19:37:40 EDT 2025
Powered by FUDForum. Page generated in 0.04796 seconds
