Home » Eclipse Projects » Technology Project and PMC » View menu.
View menu. [message #17145] Mon, 12 August 2002 19:38 Go to next message
Originally posted by: escofield.BOOGERrcn.com
I am trying to add menu's to the view.. The view consists of a tree
with different nodes. Each node has a popUp corresponding to it's
particular task. I would like to mimic this in the View's menu. How do
I get the menu to select what to display using the same/similar logic as
the popups <Filter> element that calls the testAttribute?
Erik
Example PopUp code.
<extension
point="org.eclipse.ui.popupMenus">
<objectContribution
objectClass="myGenericTreeObjectClass"
id="myID1">
<filter
name="ObjectType"
value="MyObjectType">
</filter>
<action
label="Label"
icon="icons/file_obj.gif"
class="myPopupClass"
menubarPath="additions"
enablesFor="1"
id="myID2">
</action>
</objectContribution>
</extension>
notice the objectClass is the same for every objectContribution or
popup.. The filter applied is based on a class attribute named
ObjectType that is set during the load of the tree. The
myGenericTreeObjectClass implements IActionFilter and overrides
testAttribute. TestAttribute checks "ObjectType" for "MyObjectType" and
returns true if they are equal.
I cannot figure out how to get the view's menu to have similar logic.
Re: View menu. [message #17263 is a reply to message #17145] Tue, 13 August 2002 11:36 Go to previous message
Originally posted by: david_whiteman.oti.com
Try the eclipse.tools newsgroup
"Erik" <escofield@BOOGERrcn.com> wrote in message
news:3D584712.8030403@BOOGERrcn.com...
> Erik
> Example PopUp code.
> <extension
> <objectContribution
> id="myID1">
> <filter
> name="ObjectType"
> </filter>
> <action
> label="Label"
> enablesFor="1"
> id="myID2">
> </action>
> </extension>
Re: View menu. [message #572935 is a reply to message #17145] Tue, 13 August 2002 11:36 Go to previous message
> Erik
> Example PopUp code.
> <extension
> <objectContribution
> id="myID1">
> <filter
> name="ObjectType"
> </filter>
> <action
> label="Label"
> enablesFor="1"
> id="myID2">
> </action>
> </extension>
Previous Topic:Exception while running web sphere workbench 2.0
Next Topic:Welcome
Current Time: Sun Jul 27 03:09:57 EDT 2025
Powered by FUDForum. Page generated in 0.44532 seconds
