Home » Archived » BIRT » How do I use the Report Engine bundled in a war, not 'installed' separately on the system?
How do I use the Report Engine bundled in a war, not 'installed' separately on the system? [message #181326] Mon, 31 July 2006 10:58 Go to next message
Originally posted by: Scott.Merrick.digilore.com
OK I have successfully gotten my web application to use the BIRT Report
Engine to create reports using the Report Engine copied ('installed') to
a folder on my system.
I would prefer to have it as part of the web application. But I am
having trouble finding examples to see how this is done
The BIRT Viewer web application (Birt.war contained in the
birt-runtime-2_1_0) is exactly what I want to do, bundle the Reporting
Engine in the web application preventing the need to 'install' the
Report Engine to the local file system
However have tried to find the code for the WebViewerExample and I don't
know where to look.
I see that the required libs and the 'platform' (contains the eclipse
plugins etc...) are placed in the WEB-INF dir but what do I use for the
config.setEngineHome?
With the Report Engine 'installed' in a folder on my system I use the
following code to init the report system
if( rptEngine == null ){
EngineConfig config = new EngineConfig();
config.setEngineHome("C:/Development/BIRTStuff/birt-runtime-2_1_0/ReportEngine ");
rptEngine = new ReportEngine( config );
With the Engine bundled in my application war what do I use?
What else do I need to do to get this to work??
Thanks for your time.
Scott Merrick
Re: How do I use the Report Engine bundled in a war, not 'installed' separately on the system? [message #181414 is a reply to message #181326] Mon, 31 July 2006 22:44 Go to previous messageGo to next message
--------------050708030406020006060301
Scott,
I did this a while back and had to get some help from Jason Weathersby
who gave me the following info and it works (I have attached his zip to
this post as well).
The following is quoted from Jason W.:
Attached is an example of a servlet that i modified to use for 2.1.
You will notice i set birt home to "" (this is key) and the engine is a
singleton. The directory structure under Webapps looks something like
Webapps
WebReport (my example app)
Images
Reports
WEB_INF
lib
platform
plugins
configuration.
1 - Create the platform directory and copy the
ReportEngine/configuration and ReportEngine/plugins folders from the
runtime into this directory.
2 - Copy all the jars in the birt-runtime-2_1_0/ReportEngine/lib
directory from the Report Engine download into your WEB-INF/lib
3 - Copy itext jar to the platform/plugins folder under the lowagie plugin
4 - Copy the JDBC driver to the JDBC plugin under platform/plugins
So basically you copy the pertinent parts of the BIRT example web app
into your own project keeping the deployment structure the same. I also
found that it was helpful to add some of the context-param entries found
in the example web.xml file to my own web.xml file. What jason provided
me with should get you started in the right direction.
Good Luck,
Zeb.
Scott Merrick wrote:
> Hello,
> know where to look.
> Scott Merrick
Content-Type: application/x-zip-compressed;
name="WebReport.zip"
Content-Disposition: inline;
filename="WebReport.zip"
UEsDBAoAAAAAAAClzjQAAAAAAAAAAAAAAAAKAAAAV2ViUmVwb3J0L1BLAwQU AAAACAAApc40
drh1uGgBAABXCAAAFAAAAFdlYlJlcG9ydC8uY2xhc3NwYXRozZZLSwMxEMfP Cn6HJfdkX1aK
dC2yVlBBYa3nJc2mbWoeSzJb67c3VUsfoB7EICGHScL8/snMJBkMV0pGS26d MLpAKUlQxDUz
jdCzAj2Nr3EfDS9OjgdMUudaCnNvHG0trsG+Rs9CNwVylqFoPVggFH+9jBm9 WWbsjHAmRes4
WTRAJO00m3s0ua1GdflwP768uR9V33mTYrLxVp7HE2EB206DUBxnJK3K/GCs TuskrnhrLIz0
TGgeew+xo4wsqP17EJtTC/zdpq0IxDSKiInvrKtzcupbGgysjHbYRxj7zAoM NQ1nHpuHwtpw
EW0oUNrQFrgNx4Rw+wtcIFPZAQ+DWrgwHOWzXwY7wN17nKsp+ajBOiOZr/pl liRnSS/tpf0s
0B1wqIevq5OslPhnkn4v59Mlfry6wznJqrKHX4TOs81E3MrOa3B7fDCKUajX 70Cab/EJjR23
S8nhJw2mg7aDvcd+EO/+EN4AUEsDBBQAAAAIAAClzjRIl1R9wAAAAIEBAAAS AAAAV2ViUmVw
b3J0Ly5wcm9qZWN0fZDJDoIwEIbPmvgOhLtUbx4KHjQ+gEs8lzIhJXTJtBAf X7oYXBJPne+f
5Z8p3T9kn42AVmhV5ttik2eguG6Easv8dj2td/m+Wi2pQd0Bd0ewHIVxU/Wk LqhiEqo71Gcw
Gh0lnkOCaylBuYqSFHn1NcUGIB9UD6JvLga4p4SHqZWpJijJS2NbAO+FsVB0 jSu4xilgIwsN
gHGF1MGwHby3TUzeBc9fLkGZ1/CWbkAI1Qn+bBDzlMQ3jpsHhHN/v/AJUEsD BAoAAAAAAACl
zjScKK5IJwAAACcAAAAfAAAAV2ViUmVwb3J0L0JpcnRDb25maWcucHJvcGVy dGllc2xvZ0Rp
cmVjdG9yeT1jOi90ZW1wDQpsb2dMZXZlbD1GSU5FU1QNClBLAwQUAAAACAAA pc409d+DCfcG
AADVDgAAGgAAAFdlYlJlcG9ydC9CaXJ0RW5naW5lLmNsYXNznVfZdxPXGf9d MIwQAwZhG0pa
AsQhsh1rwBQIMSUBYYOCkB3LcQJZmvF4LMaMNWJmRCBt2mZfu2QrDUmbdKVt msUmEQa3SZ7g
nCYPfchbz+lD/5Ce/u6MFhPLsYl0NHe+737L737LvVf//N/lTwBswz8ULBKI 7rdcvyefs/Km
ggaBVWP6KV2z9XxO6xseMw2fIsNVEYGutOPmNNOwrYJnanJGc82Cw8EMJDS9 YGmpAbIqOt0C
yw0nP2rl+l2n4Am0pAMfRd+yNckyXd8yPYpFQ7Fey6ajWLqGJOu7Vj5HiRVJ J+/5et4f0u2i
GcEKgWa5gGSgmChUrNFLZA8x5i1/r8DieNuQQEPSGTGXgZZVLMFSBU0CTfWQ RLEGLSrWolFg
6Z7AhlT7lgoFEYHGNBeVKY4Pm+6gPhxCdQzdHtJdS9IBM4rFaKFP/7hFLGqa IGvhWClt1mBH
aXyTis3SX6Pt6COhYDlaK3ImZWsJGIgHgTmteaZ7yjZ9LRuM0pZvnva7264/ QQq2CGgLUAvl
K6hvRksEbYy07eTS5inTloHrUHErOplywi6H9IzAlvjsbLbNZi2Dhm0Ktgqs rSWG1nOc1AIX
KrqwnRnt6+1lRtJzSHVHsIO5y/YM9Qz0RLELuxXcVq3tmkMVt6ObfPNkUbe9 VC7vuGZS9xjl
5nqAj0l831OxA9sjuENAuXffQCaVOSjZ+1TcIdlJJj2V6e2TvB4VSck7SCzJ vkxvKpBMqTgo
uYcp2ZvK9EjeERWHJa9PYInkDUjm3Sr6JDNLdcnMDkruPSqyktsVwX2sLK77 gOWyTx33jEzJ
MRX34wFOeKafdnJhrgQSddYzZ/TahiJ4SADS3sMqdAyzDGkvTP8hZ3yuAA0p GBHYOauSDMZV
G3X1cfMRxz2h9du6P+q449dWbhQGRmXbEe6m+Yp8SGKzVIzhBPuP2Co2yxIC O+Lp+XCkako1
s+NwFOQF4s4CV6GigJMsBu5Lrl8sCGyf33NFN0xP4NdDUQFxd9bXNU8bZsG3 nLwWbAYVSsWp
YNsoMAF+1teNE4OubnBnPM2tmpYSZUsJaSkRdnQi7OjEzD2gVw8qSC7/URU/ wA8F1hiuqfuV
mfAwmL+TQzluKT8S2LWALSVVB8VyPIafqHgcTzC3IYqZUgJmfCGb3Mzd6pts iwKLPENgw9eX
IpvTKDfZtoX4uAYV292WLcfyMSqF2zVv9VTrtoZBMCpa+rpKh1rKaBhwgd0L gV4vV7SyesT0
fNc5UzulluMXeEXBywJbr9esildlQStlmwyQYTsy503x2WUm7wzV9XgKfiXQ WpNJSsWM42eL
BWnfHKmKRnEWLVG8iV8reOuac2HwOMttRMVv8Db3PKPoumbeD5lfhRByu6WZ 36r4HX7PTTFX
rYukrXtemoe56fKgukZxxhS1/4jzCv5E3boCKv6Mv7AXaXjA9Jyia5j7vKxP z+MCbXP3ouVo
qXyh6Iei3fJkflfF3/AeDx3bkYtZF68nGWxFH2BCwYf0WkdAxSQaw6x4vOV8 JHetj2eK9lWj
zP4xWNlr51g6py3KNNeFEfBnm5QJzwZRCC+JjbWaS0hxbILgzQv8ReUlj29R eWvjuB7L+M6L
Cd8XQQ24K9FIzipydpHHD5d2AaunseboRTRfwLqJQHg9nysDs2vQgGa+r8YN coY/rq9qROMo
OC5pv4hv11SXSmZZRQ0F8B1s4NiGG6vKcYSfhilsrOlGAyfr6fyG0GWgdRNa Qy3xBWcayPvv
JFZfxb+ncTOR35KexLorOMdnLF5C+5FJJDKx795aws43EJ3Ensx5FGJ7q/Sd pB+O7a/SB0j3
x3qr9CHSd8buqtJp0ltjmSrdT3pjbKBKD5JeFRsKaUU675BQ7iWUzhKOdsQe LOH70zCOMk7m
kQ7KHe+Ygn0ekQzn3dgjUzjzGR7LdHZcwo8XgRnh6j7kij/FFX69cmyewEY+ N2Apx5XMfBM2
M6438a0V7djCvzi34HZGax+pu3grvRudOMYk6diKMd4jT2I7HsUOnjM78QJu w8vYjXPoZu/v
xbvUmsB+XEaSXg/hCi1cRRqfox//4rXsS1r7D+6ROeGsIjOAJ/GULBTOP41n IIjlZ/QuM7iJ
9p+lt8W014rn8Dx5V9FA7ovkfUmZl/BTvrVRo1IPBzjKT1OQ2YYJDpfwcwFZ oLX6aMESPo8y
BseI4gFqP8gifWhGeb6G1/n2S1lZpM4GtrvIkdYj0zjLennj06/Uqj6jViNh rRLj5iq2Zygt
rbdO4VwJ7xwW6faYWsIfZN11lPBX/t5nNg+3l3BhIrCygd+Pyj42B/2YI97j 7EmLFsfYRCco
kWc/OMygG/jfyIgonCnhIqllbLwpXKK1G4PIXQ5WNx0g//v/AVBLAwQUAAAA CAAApc40VdIt
dpgDAABBDAAAGQAAAFdlYlJlcG9ydC9CaXJ0RW5naW5lLmphdmGtVktv20YQ PitA/sNWyIEs
mjV6FnpwVSolYJAGJfRxMlarEb0JxWWXS9lK4f/e2ZdISYyTFLIB0+TM981r Z2bfvnn7Ruwa
qTT5yPaMCknTuun0Uitgu9mlME+eOTRayPpM2GlR0XslG1BaQDsmrWRZirqk d7CHajYwLVVJ
gVeiaYGuhdJUgflOoUZ9oKwRNLH/zmW9FeXse4BpYT85/KlXz7QFta9A0x9f oeRSAd0qtoMn
qT7R+4rprVS7pYOiRxqe9bfj00Dw3cgA/BoCQoXor/jtWK//n7UF41qqg61Y 060rwQmvWNsS
5Pcq5F8jnDRK7JkG0mqmUeuEhax77V9I3VXVbAzTHyHCbbXNh9Yg4GkgjOJT 9FbUrAoceHrx
nHn8QlTG4NQ4684PbY40U8fiogrw9lDzRyVr8Rk2ZC/Fhoha6B4fxSbcyaSS bOMCMn45lyYv
XyE8S0oJus9idHqoSMu9JbEl0TB9Ln8xMTKrMBn0Rwjc52wocS4avugkuz94 Qsc18fnDfrWt
ikQDZYou+zocomnQmXrmiUNUHmffaL5YWKkLZLpM/kiKZErhn45VbVrWeGrn rIUokMUxubl5
l+XZ++xu+f7ndw7rnZuccjsyT/9CoGqBWCt/3hZZmn24khnPNmInzRb5lYwY qhEL8zxbpNcK
xJGNWFmk2bVqYqi+YKG4ooniCzaWqysaWa5GrOCBvpKJY2v4wYE/rtdwN+k7 Wfq+fa3/fhMK
7ICexj+5xjO92DP2hH5+/C53EE1Dx54vJMLd04+P8X0X4WwinqCnP2OKApXV 9M5odcDnMR0B
QnFUKt01YS4F8hdngmn+SCJystAIkHhIBbTBsYVXF8Y/rRTjEJGzRIxtNbJ1 Tww3GpPHxwxY
CsrxYqSDMF9/BI5xjgFp8tcqyZZpnj0UyX1erB6S7AMeqIfF7XyVF38H54Zz PTjjrQxZTxJj
fn1uFOhO1YPl+k1LyG61DbRaycNg/7y6bpwwWJwdPeg1qWf0a+Zi4V+45vKH twlpjWv076kl
c/OaSb3sGhM/bI4ldx5YNXM4X9EMy/jyhuFiv9jdnlodfJQ3N36Z2vvDrms1 WWP31+7q0zD9
aNXm5u0OyUChBONcPWLpNpR3SkGt3RuJYloee2cACft4cOdGEz5bTmRekdng C2hlpzjctl41
6m84nmg4J0yIkajjwEMxzTilBueH+L5K80FThTJftlMcah4yi3/+A1BLAwQU AAAACAAApc40
AN3Np5AJAACXFAAAGQAAAFdlYlJlcG9ydC9XZWJSZXBvcnQuY2xhc3OdVwl8 FNUZ/78lyWw2
Y0IWQdYqrIiYBMKgoLUkRnMh0SWJyRKMaHWSDJvFze4yM4vEs6fWHlp71961 ra0tbUFdWGnV
2tvWXva+D3vY1t61p9b/N7PZhGzA0PyyM/Ped77v+3/fe++RZ+5/AMAZapGG gEL1NmtkwMpm
bFdDhcKyneZuc4/hWPbulOUa466bNTbzMehPKCwkKWmmhizbSWbSW3u6FNSF Csd1ZtKOa6bd
ITOVsyof7bj1oSaz/SLyjyRt1zfQnU4k05bCmbGMnTCs0VQy61iG0A3bYzAs j8Mws0mjZ6ZM
i0JVKpNIWLbCiTFx0ci5yZTBOZITRsyjkSvYSq3ppNumsKChcUihojMzZgUR piM0urZodK0Y
DeF4LNGwWGHpkTTqOAFLGaOE5caK5tc2+PZTJrkGXZvMLY1Hdqka9FiHjuMU 6mJcSm9uYsSy
4+ZIipEIxzKjjKVpJ2VcnKxq9VYQwgIs13Ey6kTHKTpCqOF63PGko1ATK6WN q9bGLMe1M5Mi
skrHStTVoAGrNDQqrDvWWCtUjmUukFQPNMSOjoYBa1eOlluek83JEh1WiyQk 1L1n1Mq6SU5o
WFsGuKJIiUnDOoVFXniTGaOnr0QI4kwmxrX2iL2JVA024GwNZymsmp8zOp6P cxRqHcsldF0r
7cYns1z84rnyOxTERrruh6nXnLBq0Io2DecqnLZzPiHScR7OV9AJpH7TpgJX sLRqLlvlU2Ks
Q0cnuugDNQxajtSewoqGxiOFvshD2U3YrOECBvronDp6wDquF/3CUgzLHuIg WmbmcI6WEGLo
1bCF7nUkp3Ckow/9bAxUOD0poDq6rsZjbw4aBhQ2zENsc3xLbMBKj1l20VoI F2O5hq0KJ8yO
ekcumSKjxH6bjkswTKwkSm72m+64wvEN5dliMLbjcg2XsePMpul4Ia5gue6W Htm3YxYA+kZ2
WqNuy5wq4zClFZwTxCjljeSEmbAcmWaYdyDBpmFms1yZQvO8MFVcnac5qWOn LC/oZnyiRCWl
Y0Lqo85h+kzH6hGLWwdiNchgl4aswklHS6MOW/Bek5AKMFMSLtHK+ZxoradW T2NX0uaaM/Zk
Na7GpIY9konyXmrttujQNbiWDXBTT2+3QiR2BLaWIK5n6L0IRcem1Eel2d+o 40V4MXcGCkgj
P6KKuTpANV6Kl2t42eFpnXRca0LHTbiZajM5Fsvi2FSz6qekS3nLnKBTt3Bl jjtGnmi5b6/C
azS8mo2uXJbab5WQaVmZSrEhvpbxm/Z8s+mMbzGzIdyG5UG8njoE5VcMdPd2 dQ9c0dnXG+++
JC7UN+p4E95MN7Pi5jlzIO/IWJye4kreSqgUi8sJ4m3c/w3Zbt6h4514l+yz BKJfn12Wk0yw
T20ux+Qx1flALp2WvbFF7LxHx3txp8KSUUbHtUhrT4/5VR03nasUUg3/j+p5 +jPLGj16P+7S
8IH5NaAyeR0fxIfYJFkP7dlsqeOGZ2KT2SX+NHxYYf08bEw3uT5vowzhbkHG R1k6slHK8OM6
9k0Vd1/OJSA2ZewJ05VN9B4d9+I+0hJFWhGG3Onm3gYOZ2sR/Qd0HERhWv+0 jkhDqTxmErg+
CeQhHZ/AJ325mUtQOGu+OZ0WKup8UMdDqCPs7Vxaxg/r+LSMK0dTGccK4bP4 vIbPsWymEVo6
Y+j4grDWZf1qNEevitvmKIWa8Yi04y/x6DgT2vFxO3O1j6YhsWjtUjj9OQ9H /hmK6bEth331
uQ9dxdMUd1u7dCAhZspqjBwBZ5Q7/9F3XMLP9uJWgt/Z8wl22WYqDo36n4Qs Ixor61Jyjh8r
NoUN8zEyu0rlAMyymaeL5eXKPprxD5/E1HxUzK4malDWVJefhssUbcnhB/rJ 7NSh/vLyYLSW
J+zYPJqKe5sX1kx/xvEq+HEdv8Sv/FvLNjvpnTRPaGg8bF8qEtjNf6NwXusp XX2d8eH+7qgo
j/Zv7Yj1dEZXNBvGtvWdhtEV7/IJG9auOyPKEkg7SVmvmTKM7t4VvKn8Vvav 3zHlc9gI4km5
04iCtiD+yIqIRls3d7d3tbXGe+Kx7rb2aBGQrYY/0WoImcx/5k5D5o6+rmGO /srzc5R/cd6A
ovwXs3/X8ZR0skqvREP4J/6t4V+lPXp639LxH/yX6uQIlzIdh74ednjzJltE 5TOi8n9M8Vxn
s6GgUozmmmjOYb6i7rgV7e8bjEd5oB/PjAXVAoadHhu+y6qSeGv1MiZBUpqu gl7v2ZHKOeNi
7GEy2H4HoHN2sbRpfK5sCfrlasjjtqrT1UJRVcsJOV9LNe9IJliCg5mcPWpt Sgrqaku3xLWi
D6eAbQng70RUooojjaMAgvzxeslv76rKdxXnalFHjoUcNfMtf9Xh+oNYdA8i +zyx5/EZQoDP
KNmX4CRvFmQ+uSTayhklfE0HsKxJ3YfotGyt58ypqMByVGOlJ6/73FjBedG0 sqTpfL6FVktN
pzXdi2gBpyvM1tZEbau5hDUztNWWtDWRFiBNFhjgsgzRHOhgMEIkb1gTPqOA 9QGsDr+ggJYA
elcX0K5QAE+cGyuaIhUHcRFXcAgXDx/A4MbKSOUhxIfJNKS44116AFeGR/IY y2M8j6silZGK
8EgB6QDycPYjsh+7hT18HflKpCn2G/bjJR71FXNRX3kIt9Hk7RurIlXh10Uq 83jDNgmBSJD5
LcI85cEdFGr2BQt4ewAbNeGMaAW8m4NgJBipKuB9ARzC3VT5kY3Vkerw3jw+ FqleU8B+RZt5
8lQXcH8AkWABDyjv9SmFu3C8yOfxmUNoHo4ED+CLD+5jVPeqFWoFd9IFXh5G sJTPc4mIdtSj
A8t4cz0d3VjHq+gWXIDtvGlehwtxB2+Nd3JmLwbwHQzicd5FnsQQq28bnsYw S+VSVY/taiku
o/bL1UrenRpxpVpPC5Lba6BLzvzcel9fxqNQ3tdX8FXmt16diq/h6/RrmVqC b+AxYmOdqsA3
8S1U0vbt+DYtV/F3Eb6L70GjbuV/0Zs2fB8/4CqeIl5+iB+hWgkWf4yfcO6n PraKOn7mldLP
58IWHuN3Bd+DU9hikH+h0Nsc/nUeTzSHf+89/+A9/+Q9/5LH35qb8vhHHk83 L5J8PMFXwH9V
yCuvqvirLkGfrtbxuYuO2fxyaNjFYuRI282av5rh30OHJnEWg9aKa9HpJeB6 9OIGBv9GL5xN
vpt+OOVLhSSc3leNhJOau3CT0hlOpY7jyF9sBXmavaWeKVmQmYOqdnaDuJlS t8woyYqpklT1
wqnCzwJQSwMEFAAAAAgAAKXONBGHEkd8BQAArBEAABgAAABXZWJSZXBvcnQv V2ViUmVwb3J0
LmphdmHtV91z2jgQf+Zm7n/Y8/TBtMRum35MJyRzSSAXbigwxLleZzqTEUaA WmG7kpw218n/
fqsPY7AhLX24p0tAtrS7P+2XVsuvv7BllgoFH8ktCVga9IbdrzHNFEuToxpx JFii3gmmqKgQ
c8V4cEnk4i3JtpF4Op+zZB706S3lDzLg06Bv8HwNJBW3nKrgyj7P00TRr+ro Ya6VKbv4Fkpl
wSUOTuBH+cb0c07lHuwySxNJ181KxTygMWeZpMGECRUIqtcDmqAfaEAyFnTN 6zlKKpIoebSP
7GX0tj+myZQK56qflB4a/+0l3BubpXGeJGTC6Z6yeXKaTO3eEZGf9pQ2S9Zv KKn/s3zCWQwx
J1LCOzqxLIAewT0krEUJvmn+Rvj4MY7wGMwY4pgJdksUBQyDQqgZSwgHniZz wIAzwv+iQqKT
rnsdOIaDw1cvXz1/+vzNm2cvXr98efjm1eHr/tE6rgmoyGOVCkhnoBYU0slH GqugtuOGQaCt
Xl/A3ZKc8yMjkCpEoNNCSXuOgNvHsZsHc6rsmw9e1aEeNDUUfqzPSm/5Te2b RkPmGUoarvtN
X3WoNQndUNhUHAZoT8SJtayEvk3ZFKZaKL3bQA9Wi0cQhvBnLhVkuZLgOYIH +GDoe5Zo67Rg
1S8FxkrTTV0jVG6a/oEBX1K1SKc7FV7xM1mw4ltMOEc/f1nQBAjMUrGEBZHA UEdF5nBLeE4L
diwThON6CnMEtnB2/D0jgixB2EKi91+9S0xMmNyZNQwPTZCcrjSkYhPAlRZN X01WEKWQhigB
HYRaiPSLhGq1BDYDkgAVQmdoHOdC0OmmSG/4A9yVeFun+/Uyqi1vQb1eWoOa OsSNHaq21jVx
B7ihv1oykPaiQIOju4z6nq6D4UItuWcyoxGG29jAI1mGShONGWbTmQcmGR8N hoODQf/q4Nmj
TeFLSqboYd9zKAcdhvpLpuW9lscSrssR1g1OE7KkxwptDjRuFXZ99vxRYcqV zXdb7gYIAMfa
Y/osj3QOUIWH0huvyM64zZsSZFyKXVGpC5bf1JNNPt8KK8z5YEu9OWPFRIuW M1/GVlB/a3cP
7rs202WLfoGSa3PrDV7t3jMiaW9J5vR63PedBZaM9quF33zihUzTpbcDwUh3 mKC65t6hrgiB
lhFu5Evp0gRuyyU+fDA9S3DRG3Rb4BlWmBZY4METeADPRfBOKroM0hzDrlso nvieVFOcw554
hX6u1Wrb3GjVnXkCsX1BLufw78u4CJSSAZZeHyp9SHA6Gp0PB1H37+hGY9yM u4NOd3zj1lqV
aJdKVxoDXf/ZPLH5Ju7045s563Ydta4V9jSjiV3oGB6/7it7TKSns8J7Uh4a p0ej1mGAwmHb
ZrGgeAdX2X1w6hXBbWh5nWWnWVZk8przi33NUO2rIDUP6SJUJftO1nHpTYa5 wphc4K1DlF/l
D4bX0eg6urkYjt+e2uA4hDD8SYxR52KXElcKHbT0TRWcVxZtqpa+2bDKIa2z iFwbW85jnkrq
Vu6xEscL8Ms6T5vfSp9Sc6ZwYxJ/igSJtVh5ZWi/1m4NH4p0uMfhflt7MErl f9of4H3xf4Ng
3L69Q7DPHV2Ce9m/Uygkv9sprP3yBV22j1ebYuo7gss7JOMD/8pa3/6tMzyP 3o+65oTD6Pqs
3zuHD95BGL47PA/DTtSxlBfB02eASZzY5oHwMOwOPngn3gp6DVRLbKUAtC+7 p52TdtSL+t2T
08IX7dAutENN3iV6Nuy8r9E0BWym46dG1e2CuZb1ryy/uQW4BbnEW8ek2Gh4 FbkTsEOHsFCi
bnVYNXvGc7kofb8qHfWT3UvQq4Szf8jDv1P2TX66NZkZ7oY/bXahmAq21k5p dpzqNJyxubOn
sMEM/wJQSwECFAAKAAAAAAAApc40AAAAAAAAAAAAAAAACgAAAAAAAAAAABAA AAAAAAAAV2Vi
UmVwb3J0L1BLAQIUABQAAAAIAAClzjR2uHW4aAEAAFcIAAAUAAAAAAAAAAAA IAAAACgAAABX
ZWJSZXBvcnQvLmNsYXNzcGF0aFBLAQIUABQAAAAIAAClzjRIl1R9wAAAAIEB AAASAAAAAAAA
AAAAIAAAAMIBAABXZWJSZXBvcnQvLnByb2plY3RQSwECFAAKAAAAAAAApc40 nCiuSCcAAAAn
AAAAHwAAAAAAAAAAACAAAACyAgAAV2ViUmVwb3J0L0JpcnRDb25maWcucHJv cGVydGllc1BL
AQIUABQAAAAIAAClzjT134MJ9wYAANUOAAAaAAAAAAAAAAAAIAAAABYDAABX ZWJSZXBvcnQv
QmlydEVuZ2luZS5jbGFzc1BLAQIUABQAAAAIAAClzjRV0i12mAMAAEEMAAAZ AAAAAAAAAAAA
IAAAAEUKAABXZWJSZXBvcnQvQmlydEVuZ2luZS5qYXZhUEsBAhQAFAAAAAgA AKXONADdzaeQ
CQAAlxQAABkAAAAAAAAAAAAgAAAAFA4AAFdlYlJlcG9ydC9XZWJSZXBvcnQu Y2xhc3NQSwEC
FAAUAAAACAAApc40EYcSR3wFAACsEQAAGAAAAAAAAAAAACAAAADbFwAAV2Vi UmVwb3J0L1dl
YlJlcG9ydC5qYXZhUEsFBgAAAAAIAAgAIwIAAI0dAAAAAA==
--------------050708030406020006060301--
Re: How do I use the Report Engine bundled in a war, not 'installed' separately on the system? [message #182831 is a reply to message #181414] Fri, 04 August 2006 11:30 Go to previous message
BTW, I have added some examples on the Eclipse Wiki.
http://wiki.eclipse.org/index.php/BIRT_Report_Engine_API
Jason
"Zeb Olaf" <zebonebo@gmail.com> wrote in message
news:eamf5t$f18$1@utils.eclipse.org...
> Scott,
> this post as well).
> Webapps
> Images
> Reports
> WEB_INF
> lib
> platform
> plugins
> configuration.
> Good Luck,
> Zeb.
>> Hello,
>> know where to look.
>> Scott Merrick
Previous Topic:Merge two rows into one?
Next Topic:DB2 Driver connection issues
Current Time: Fri Jul 18 04:08:27 EDT 2025
Powered by FUDForum. Page generated in 0.06834 seconds
