Home » Eclipse Projects » Subversive » Ignoring resources from Version Control
Ignoring resources from Version Control [message #17115] Thu, 24 April 2008 05:03 Go to next message
Originally posted by: stefan.hansmann.googlemail.com
When I check out a project from the repository and than add a file on the
local copy later it is no problem to set the svn:ignore property for it so
it wont be considered in the next synchronisation.
but when I want to ignore a checked out file it is not possible. what do I
have to do to ignore checked out files to get updated in the future
synchronisations?
for example: you checked out a project containing a specific configuration
file. to test your changes on your local system you have to change the
database settings in this file. for sure you dont want this file to be
committed in the next step...
thanks for help
Re: Ignoring resources from Version Control [message #17144 is a reply to message #17115] Thu, 24 April 2008 05:32 Go to previous message
hi,
SVN doesnt support this. the SVN help suggest to have a template for
such configs in the repository which needs to be renamed after first
check out.
we do it like so that we append .#~#~# to the file name. the developer
just has to remove that suffix and then adjust it to his needs. eg:
db.properties.#~#~# -> db.properties
we found that this ending is VERY unique and doesnt cause any trouble
(escaping) on windows or unixes.
> the local copy later it is no problem to set the svn:ignore property for
> it so it wont be considered in the next synchronisation.
> I have to do to ignore checked out files to get updated in the future
> synchronisations?
> configuration file. to test your changes on your local system you have
> to change the database settings in this file. for sure you dont want
> this file to be committed in the next step...
> thanks for help
Thomas Menzel (aka: tom)
Previous Topic:Repository Location on a FileServer
Next Topic:Replace with...
Current Time: Tue Jul 22 09:05:42 EDT 2025
Powered by FUDForum. Page generated in 0.25648 seconds
