Same Sized Cell in XLS [message #181291] |
Mon, 31 July 2006 09:24 |
Originally posted by: arvimail.gmail.com
I have tried BIRT 2.0.1, and exported to HTML, PDF and XLS formats.
The problem occurs when i export to XLS format. When the data is read from
the database and is populated to the excel sheet, it uses the size of
cells as per the HTML and PDF formats. That is, the size of the cells in
the first row of the sheets are of size left for the Top Margin. Similarly
the other cell sizes.
Can I fix this size to a standard size for all the data populated cells
and other format for the headers and footers?
--Arvi.
FUDForum. Page generated in 0.03954 seconds
