Home » Archived » Test and Performance Tools Platform (TPTP) » Starting RAServer
Starting RAServer [message #17106] Thu, 28 April 2005 04:15 Go to next message
Originally posted by: assafn.yahoo.com
I get the following error when starting RAServer:
/RAServer: error while loading shared libraries: libxerces-c.so.24:
cannot open shared object file: No such file or directory
I am lost at finding a solution. Any help?
Assaf
Running RedHat 8.
JVM 1.5.0_02
I have the following settings:
$PATH
/root/hyade/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/u sr/sbin:/usr/bin:/usr/X11R6/bin:/usr/local/java/bin:/root/bi n
$LD_LIBRARY_PATH
/usr/local/java/jre/lib/i386/server:/root/hyade/lib:/usr/lib :
ls /usr/lib/libstdc++*
/usr/lib/libstdc++-2-libc6.1-1-2.9.0.so /usr/lib/libstdc++.so.2.8
/usr/lib/libstdc++-3-libc6.2-2-2.10.0.so /usr/lib/libstdc++.so.2.8.0
/usr/lib/libstdc++-libc6.1-1.so.2 /usr/lib/libstdc++.so.2.9
/usr/lib/libstdc++-libc6.2-2.so.3 /usr/lib/libstdc++.so.2.9.dummy
/usr/lib/libstdc++.so.2.7.2 /usr/lib/libstdc++.so.5
/usr/lib/libstdc++.so.2.7.2.8 /usr/lib/libstdc++.so.5.0.1
Re: Starting RAServer [message #17166 is a reply to message #17106] Thu, 28 April 2005 16:29 Go to previous message
Assaf,
The shared library libxerces-c.so.24 is located in the lib directory (look
for lib under
the Agent Controller installation directory). You need to do the following
before running RAServer.
1. Add the path to lib directory to the LD_LIBRARY_PATH environment
variable.
2. Set the RASERVER_HOME variable pointing to the installation directory
path.
3. Run SetConfig.sh (located in the bin directory). This creates the agent
controller configuration file.
Please read the detailed instructions on Getting Started with Agent
Controller at the following location.
http://eclipse.org/tptp/home/downloads/installguide/agentcon troller_40/linux_ia32/getting_started.html#cfgstart
Vishnu
"Assaf" <assafn@yahoo.com> wrote in message
news:84209847411624fc03c0af9bde6f8335$1@www.eclipse.org...
> Assaf
> Running RedHat 8.
> JVM 1.5.0_02
> $PATH
:/usr/X11R6/bin:/usr/local/java/bin:/root/bin
> $LD_LIBRARY_PATH
Previous Topic:Is there a tool for feature-tracking and regression testing?
Next Topic:Is it possible to use the TPTP framework to test J2EE based applications
Current Time: Mon Jul 14 20:29:19 EDT 2025
Powered by FUDForum. Page generated in 0.27140 seconds
