WebTools 2.0M2 missing dependencies?? [message #181130] |
Sun, 08 October 2006 08:51  |
I just tried to use WTP 2.0m2 using the complete set as specified on the
download page (eclipse 3.3m2 enz). But when I try to add a feature using
the Update Manager I get errors stating that a lot of internal plugin
dependencies are not OK:
The current configuration contains errors and this operation can have
unpredictable results.
WST XML Core (1.6.0.v200609120056--3YIAAYAjHMDXHW) requires feature
"org.eclipse.rcp (3.2.0)", or equivalent.
WST Relational Database Core (1.5.1.v200608082043--3YIAAYAhEOHKEP)
requires feature "org.eclipse.platform (3.2.0)", or equivalent.
WST Web Core (1.5.1.v200608082043--4hNDDhDtMTHeIN) requires feature
JST Enterprise Core (1.5.1.v200608082043--2PD88P8YAVD8JG) requires
WST Relational Database Adapters
(1.5.1.v200608082043--Cq0bcpdMx4piv_) requires feature
JST Enterprise UI (1.5.1.v200608082043-pEBq_jDGdFuyHoX) requires
JST Common Core (1.5.1.v200608082043--0842282_363738) requires
JST Server Core (1.5.1.v200608082043--2PD88P9LBK778A) requires
WST Web Services Core (1.5.1.v200608082043--4hNDDhDvGZLWQW) requires
JST Web Core (1.5.1.v200608082043--87cMN7P_S_XKki) requires feature
WST Server Core (1.5.1.v200608082043------1G955G6C5J) requires
feature "org.eclipse.rcp (3.2.0)", or equivalent.
Anyone knows what causes this? It seems like the M2 build is wrong. As
was the M1 build which exhibits the same behaviour.
Re: WebTools 2.0M2 missing dependencies?? [message #182946 is a reply to message #181138] |
Mon, 20 November 2006 05:47  |
Unfortunately this issue is still open. This makes testing very complicated, becuse after the installation of WT 2.0 M2 or M3 the Update Manager and the installation of can no longer be used.
Johannes Weberhofer
David Williams schrieb:
> On Sun, 08 Oct 2006 08:51:56 -0400, Frits Jalvingh <jal@etc.to> wrote:
>> the download page (eclipse 3.3m2 enz). But when I try to add a feature
>> using the Update Manager I get errors stating that a lot of internal
>> plugin dependencies are not OK:
> Thanks for the reminder. We have not yet updated our features to spec the
> correct pre-req features yet. Everything should run fine, if you just
> unzip the
> zip files, since the plugins are fine. We need to ether update those
> out-of-date feature specs, or remove them.
> I've updated bug 154979 to track this for M3.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=154979
FUDForum. Page generated in 0.03722 seconds
