Home » Eclipse Projects » Remote Application Platform (RAP) » RAP Demo on Tomcat
RAP Demo on Tomcat [message #17097] Tue, 17 April 2007 07:39 Go to next message
Originally posted by: liat_golan_herman.walla.co.il
What are the steps to deploy eclipse RAP Demo to the tomcat?
I am able to run it using the eclipse but don't know what is required for
the tomcat deployment.
Liat
Re: RAP Demo on Tomcat [message #17388 is a reply to message #17097] Tue, 17 April 2007 16:56 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi Liat,
> for the tomcat deployment.
We will provide a RAP-Tomcat-HOWTO within the next couple of days. We'll
let you know when it's available.
Ralf
Re: RAP Demo on Tomcat [message #17952 is a reply to message #17388] Wed, 18 April 2007 02:21 Go to previous messageGo to next message
Thanks a lot :)
Liat
Re: RAP Demo on Tomcat [message #18731 is a reply to message #17952] Thu, 19 April 2007 07:36 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
The RAP CVS contains a new project (org.eclipse.rap.demo.feature) that
demonstrates how to create a deployment archive (WAR). The deployment uses
the org.eclipse.equinox.servletbridge as servlet container hook. The
documentation is currently integrated in the project - see the
deployment_tutorial.html in the root directory.
Ciao
Frank
"Liat Golan" <liat_golan_herman@walla.co.il> schrieb im Newsbeitrag
news:38b2534c82735bd8b0abf9273f2e9e8f$1@www.eclipse.org...
> Thanks a lot :)
> Liat
Re: RAP Demo on Tomcat [message #19831 is a reply to message #18731] Sun, 22 April 2007 09:53 Go to previous messageGo to next message
I tried to download the projects using the CVS, there was no
"org.eclipse.rap.demo.feature" was imported.
after manually adding a line with the "org.eclipse.rap.demo.feature" the
project was added, but had no deployment_tutorial.html.
Can you check the CVS, or add to wiki the explanations of how to deploy
the demo to TOMCAT, using war.
Liat
Re: RAP Demo on Tomcat [message #19875 is a reply to message #19831] Mon, 23 April 2007 05:10 Go to previous message
I just checked the CVS - the current version number of the
deployment_tutorial.html is 1.1, so it is in the repository. It is true that
the 'org.eclipse.rap.demo.feature' isn't added to the rap.psf file, so it
has to be checked out manually. Maybe this will be changed in the future and
the tutorial will be added to the next milestone help plugin. After that we
will provide it online as an infocenter installation.
Ensure that you have checked out the 'org.eclipse.rap.demo.feature' and not
the 'org.eclipse.rap.feature' which is used for the milestone build. We also
tried the anonymous account but the deployment_tutorial.html was there.
Maybe try the CVS Repository Exploring perspective to find it. If you are
still not able to check out the complete project, please give us some more
hints for troubleshooting, since maybe not only the tutorial is missing - so
putting the tutorial into the wiki would not be the solution.
Ciao
Frank
news:5fa94cadedb2df1c780fa72e9e9e170a$1@www.eclipse.org...
> Liat
Previous Topic:CVS Server Timeout
Next Topic:RAP widget library
Current Time: Fri Jun 06 21:22:25 EDT 2025
Powered by FUDForum. Page generated in 0.04080 seconds
