PDE Automated Testing Classloader problem [message #17078] |
Mon, 18 August 2008 17:36 |
Originally posted by: michael.urban.ipsysi.com
I am working on setup up automated build and testing. I am following the
example outlined here:
http://www.eclipse.org/articles/article.php?file=Article-PDE JUnitAntAutomation/index.html.
but am running into a no Classloader error, when the
org.eclipse.pde.junit.runtime.coretestapplication (in the following ant
command):
<java dir="${plugin.dir}" classname="org.eclipse.equinox.launcher.Main"
fork="yes" classpathref="equinox.launcher.class.path">
<arg
line="-application org.eclipse.pde.junit.runtime.coretestapplication
-debug -clean -data ${build.output.dir} -dev bin -port ${pde.test.port}
-testpluginname ${tested.plugin.name} -classnames ${test.classes.list}" />
</java>
Here is the error from the configuration log file,
java.lang.IllegalArgumentException: No Classloader found for plug-in {my
plugin name}
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.getClassLoader(RemotePluginTestRunner.java:73)
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.getTestClassLoader(RemotePluginTestRunner.java:67)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadC lass(RemoteTestRunner.java:683)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadC lasses(RemoteTestRunner.java:425)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:445)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:58)
org.eclipse.pde.internal.junit.runtime.CoreTestApplication.r un(CoreTestApplication.java:24)
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:572)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:171)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
I have looked around and haven't been able to fix it. Does anyone know
what might be cuaseing this? And more importantly how to correct it?
-Mike
FUDForum. Page generated in 0.04938 seconds
