Pointing eclipse to use a particular JVM [message #180921] |
Mon, 20 November 2006 06:04 |
Originally posted by: sri1025.gmail.com
I am running eclipse on Ubuntu Linux and by default it seems to be picking
up the default JRE which is GCJ or something like that...
I want to point eclipse to use Sun's JRE which is at '/java' on my
computer. So I changed the eclipse.ini file and added this line as the
first line to it:
-vm /java
But this doesn't seem to work and eclipse still runs on the GCJ JRE and
not the Sun JRE on '/java'
Is there any other modifications that I need to do?
Thank you,
Srikanth
Re: Pointing eclipse to use a particular JVM [message #180937 is a reply to message #180929] |
Mon, 20 November 2006 07:14 |
Remy Suen wrote:
> Since you said the Sun JRE is _at_ '/java', I presume that means '/java'
> is the name of the folder of where you extracted the downloaded .bin
> file? '-vm' needs to point to the actual 'java' binary file. I think the
> path is something like /java/jre/bin/java or maybe /java/bin/java?
> Update your eclipse.ini file and try again.
> Rem
Thank you Rem, that did it!
FUDForum. Page generated in 0.08261 seconds
