Home » Modeling » OCL » Playing with setContext
Playing with setContext [message #17057] Thu, 12 April 2007 06:32 Go to next message
Is it possible to play with setContext / setOperationContext with OCL /
OCLHelper to parse a string like this
"context myMethod(i : MyObject) : MyObject
pre
cond1: true = true
or like this
pre
true = true
and setting the good EPackage / EClass for the method ?
It's the same question as yesterday but I don't need the class name in
the condition (I can infer it with the model).
Re: Playing with setContext [message #17119 is a reply to message #17057] Thu, 12 April 2007 12:20 Go to previous message
Hi, Youmm,
Using the OCLHelper.setOperationContext(...) method, you specify both the
classifier and operation context of the constraint (note that the
classifier could be one that inherits but does not define the operation).
With the helper, you provide only the constraint expression to the
createPrecondition() method, e.g.:
EClass myEClass;
EOperation myEOperation;
helper.setOperationContext(myEClass, myEOperation);
Constraint ct = helper.createPrecondition("true = true");
ct.setName("cond1");
The OCLHelper is intended primarily for parsing constraints embedded in
models, where normally the constraint text consists of the expression only
(the constraint name and context being provided via separate attributes of
the constraint element).
HTH,
Christian
Youmm P. wrote:
> Hello,
> pre
> cond1: true = true
> or like this
> pre
> true = true
Previous Topic:OCL to Java
Next Topic:OCL pre conditions and specific parsing
Current Time: Sun Jun 08 01:57:48 EDT 2025
Powered by FUDForum. Page generated in 0.03174 seconds
