Home » Newcomers » Newcomers » eclipse does not start :(
eclipse does not start :( [message #17046] Wed, 26 January 2005 02:54 Go to next message
Originally posted by: uac.medint.aon.at
i'd appreciate any help on the following issue:
configuration:
java: jre 1.4.2_06, installed with the respective sdk-download.
eclipse: installed from eclipse-RCP-3.0.1-win32.zip
plugin: c++ development plugin installed from
org.eclipse.cdt-2.0-win32.win32.x86.zip
the config.ini created by the eclipse installation did not contain values
for most of
the keys - normal? after removing all the comments, the config.ini boils
down to:
osgi.bundles=plugins/org.eclipse.core.runtime_3.0.1
eclipse.product=features/org.eclipse.cdt_2.0.0
eclipse.buildId=M200409161125
eof=eof
i also tried to change some of the values, but it did not help. the
comments in the
config.ini are not helpful to the newcomer. i could not find anything
helpful for my
problem in any of the docu-files coming with the eclipse distribution.
when i start eclipse it fails (log file contents):
!SESSION Jan 25, 2005 23:08:51.343
java.version=1.4.2_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
!ENTRY org.eclipse.osgi Jan 25, 2005 23:08:51.343
!MESSAGE Bundle plugins/org.eclipse.core.runtime_3.0.1 not found.
!ENTRY org.eclipse.osgi Jan 25, 2005 23:08:51.359
!MESSAGE Application error
!STACK 1 java.lang.IllegalStateException: Unable to acquire application
service.
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:267)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
what is the particular problem here?
may main problem is that i am not familiar with the technical terms
related to eclipse.
e.g. the log quoted above states "unable to acquire application
service"... but what is
an application service in this context? or: what is an osgi-framework? and
so on - is
there any docu around that explains this basic stuff?
have a nice day
ulrich
Re: eclipse does not start :( [message #17136 is a reply to message #17046] Wed, 26 January 2005 07:32 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
Ulrich,
Start over again with the download and clean install of
eclipse-SDK-3.0.1-win32.zip. The RCP download you started with is the
basis for developing for the Rich Client Platform, not the full fledged
Eclipse IDE.
Hope this helps,
- Jeff
> configuration:
> related to eclipse.
> and so on - is
> have a nice day
> ulrich
Re: eclipse does not start :( [message #18098 is a reply to message #17136] Thu, 27 January 2005 02:09 Go to previous messageGo to next message
On Wed, 26 Jan 2005 07:32:15 -0500, Jeff Myers <myersj@nospam.gmail.com>
> eclipse-SDK-3.0.1-win32.zip. The RCP download you started > with is
> the basisfor developing for the Rich Client Platform, not the full
> fledged Eclipse IDE.
ooops.
thanks for the hint, seems that i was not sufficiently careful when
chosing my download...
have a nice day
ulrich
Re: eclipse does not start :( [message #28722 is a reply to message #17136] Tue, 22 February 2005 16:26 Go to previous message
Originally posted by: njc.wolfgang.uucp
On Wed, 26 Jan 2005 07:32:15 -0500, Jeff Myers wrote:
> Ulrich,
> Eclipse IDE.
> Hope this helps,
You just saved me a whole lot of time trying to fix this one! Thanks!
Linux Home Automation Neil Cherry ncherry@comcast.net
http://home.comcast.net/~ncherry/ (Text only)
http://hcs.sourceforge.net/ (HCS II)
http://linuxha.blogspot.com/ My HA Blog
Previous Topic:how to apply patch?
Next Topic:bug? : Eclipse 3.01 -- hangs when opening a java file or when switching perspectives
Current Time: Fri Jul 18 07:23:51 EDT 2025
Powered by FUDForum. Page generated in 1.12585 seconds
