Eclipse/CVS problems [message #180453] |
Wed, 15 November 2006 21:41 |
Originally posted by: cleber.cisunix.unh.edu
Hi all.... I'm having a problem setting up a CVS connection to eclipse.
When I enter the name of the server, it tells me that eclipse cannot find
the host. This is in Windows. Now, when I run the same application on
Linux, it can find the server, so I know it's not a problem with the
server, but with my settings on Eclipse. I think the problem is in how
Eclipse is trying to connect to the network. To test this, I tried
updating Eclipse to see if I was missing a plugin, but the update manager
can't connect to the internet either. Anyone have any idea how I can
change the way Eclipse connects to the internet, or have any other ideas
about how to fix this? Thanks.
Re: Eclipse/CVS problems [message #180510 is a reply to message #180453] |
Thu, 16 November 2006 01:39 |
> find the host. This is in Windows. Now, when I run the same
> application on Linux, it can find the server, so I know it's not a
> problem with the server, but with my settings on Eclipse. I think the
> problem is in how Eclipse is trying to connect to the network. To test
> this, I tried updating Eclipse to see if I was missing a plugin, but the
> update manager can't connect to the internet either. Anyone have any
> idea how I can change the way Eclipse connects to the internet, or have
> any other ideas about how to fix this? Thanks.
Need to start with the basics...
Can you connect to the Internet from other applications, like IE or FireFox?
Do you have a proxy server in the way?
Wayne
Re: Eclipse/CVS problems [message #180526 is a reply to message #180510] |
Thu, 16 November 2006 02:33 |
I have no issue connecting to the internet using any other applications,
just with Eclipse. And there is no proxy either. I have a straight
connection to the network.
Re: Eclipse/CVS problems [message #180608 is a reply to message #180526] |
Thu, 16 November 2006 15:55 |
Can you browse to http://update.eclipse.org/updates/3.2/ ?
What CVS host/repository are you trying to access?
Wayne
Re: Eclipse/CVS problems [message #180682 is a reply to message #180608] |
Thu, 16 November 2006 22:55 |
I can browse to that url with Firefox, but when I try to access it with
Eclipse, I get the following:
Network connection problems encountered during search.
Unable to access "http://update.eclipse.org/updates/3.2".
Unable to access site: "http://update.eclipse.org/updates/3.2"
[update.eclipse.org]
The cvs repository I am trying to access is a repository set up for a
coding project I am doing with a few classmates (I'm a college student).
I've managed to access it using Cygwin to interact with the repository, so
the problem isn't with the repository. Also, other people in my group
have been able to access the repository through Eclipse on Windows, so the
problem is specifically with my install.
~Christina
Re: Eclipse/CVS problems [message #180740 is a reply to message #180682] |
Fri, 17 November 2006 13:37 |
> student). I've managed to access it using Cygwin to interact with the
> repository, so the problem isn't with the repository. Also, other
> people in my group have been able to access the repository through
> Eclipse on Windows, so the problem is specifically with my install.
> Thanks, ~Christina
Are there any related messages in the log file (workspace/.metdata/.log)?
Wayne
Re: Eclipse/CVS problems [message #180855 is a reply to message #180740] |
Sat, 18 November 2006 05:47 |
Yes there are. Here's my log file entry (with server name/address taken
out):
!SESSION 2006-11-18 00:41:12.921
eclipse.buildId=M20060921-0945
java.version=1.5.0_09
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.team.cvs.core 4 -6 2006-11-18 00:44:19.796
!MESSAGE Could not connect to (cvs server name deleted): Cannot locate
host: (cvs server name deleted)
!STACK 0
java.net.UnknownHostException: (cvs server name deleted)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
at org.eclipse.team.internal.ccvs.core.util.Util$1.run(Util.jav a:171)
at java.lang.Thread.run(Unknown Source)
FUDForum. Page generated in 0.08512 seconds
