linux - root vs. standard user [message #17017] |
Tue, 25 January 2005 23:34  |
Originally posted by: je6419.hotmail.com
I'm having a small bit of trouble with eclipse, hoping someone can help.
I unzipped the 3.1 environment distribution in my home dir. As root I
moved the directory to '/usr/share/eclipse/'.
Running the program as root is fine but when I try to execute the program
as a standard user I get the following errors in the config log:
!SESSION 2005-01-25 23:29:06.717
eclipse.buildId=unknown
java.version=1.4.2_07
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.update.configurator 2005-01-25 23:29:06.718
!MESSAGE Could not load from shared install
!STACK 0
java.lang.Exception
org.eclipse.update.internal.configurator.ConfigurationParser .processConfig(ConfigurationParser.java:299)
org.eclipse.update.internal.configurator.ConfigurationParser .startElement(ConfigurationParser.java:105)
at org.apache.crimson.parser.Parser3.maybeElement(Parser2.java: 1672)
at org.apache.crimson.parser.Parser2.parseInternal(Parser2.java :667)
at org.apache.crimson.parser.Parser2.parse(Parser2.java:337)
at org.apache.crimson.parser.XMLReaderImpl.parse(XMLReaderImpl. java:448)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:345)
org.eclipse.update.internal.configurator.ConfigurationParser .parse(ConfigurationParser.java:69)
org.eclipse.update.internal.configurator.PlatformConfigurati on.loadConfig(PlatformConfiguration.java:1006)
org.eclipse.update.internal.configurator.PlatformConfigurati on.initializeCurrent(PlatformConfiguration.java:676)
org.eclipse.update.internal.configurator.PlatformConfigurati on. <init>(PlatformConfiguration.java:86)
org.eclipse.update.internal.configurator.PlatformConfigurati on.startup(PlatformConfiguration.java:630)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.getPlatformConfiguration(ConfigurationActivator.java:323 )
org.eclipse.update.internal.configurator.ConfigurationActiva tor.initialize(ConfigurationActivator.java:108)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:71)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:417)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:366)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:999)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:577)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:488)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:444)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:186)
org.eclipse.osgi.framework.eventmgr.EventThread.run(EventThr ead.java:104)
!ENTRY org.eclipse.core.runtime 2005-01-25 23:29:06.751
!MESSAGE Product org.eclipse.platform.ide could not be found.
!ENTRY org.eclipse.osgi 2005-01-25 23:29:06.769
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:198)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:710)
at org.eclipse.core.launcher.Main.main(Main.java:694)
The permissions on the files in question are:
drwxr-xr-x 6 root root 4096 Jan 25 23:26 .
drwxr-xr-x 155 root root 4096 Jan 25 19:33 ..
drwxrwxr-x 6 root root 4096 Jan 25 23:27 configuration
-rw-rw-r-- 1 root root 15048 Dec 16 20:26 cpl-v10.html
-rwxr-xr-x 1 root root 29080 Dec 16 20:26 eclipse
-rw-rw-r-- 1 root root 59 Dec 16 20:26 .eclipseproduct
drwxr-xr-x 10 root root 4096 Jan 25 23:27 features
-rw-rw-r-- 1 root root 10796 Dec 16 20:26 icon.xpm
-rw-rw-r-- 1 root root 5810 Dec 16 20:26 notice.html
drwxr-xr-x 86 root root 4096 Jan 25 23:27 plugins
drwxrwxr-x 2 root root 4096 Dec 16 20:26 readme
-rw-rw-r-- 1 root root 19558 Dec 16 20:26 startup.jar
Ideally I just want to run without having to sudo. If you need anymore
info just let me know.
Jude
Re: linux - root vs. standard user [message #29833 is a reply to message #29831] |
Thu, 03 March 2005 02:37   |
Eclipse Webmaster Messages: 607353 Registered: July 2009 |
Check out this snippet of information I got when I asked about running
the infocenter help as a non-root user, where Eclipse is installed in a
non-writable location:
"In addition to -eclipseHome, you can use -data and -configuration.
With the latter two pointing to writable area, the first one (and
eclipse) can be at read only location."
In this case, -data and -configuration point to the user's home
directory, and -eclipseHome points to the application that is read-only.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=85110
Denis
Dave Trainer wrote:
> Muhammad Dwyer wrote:
>> Oops,
>> I tried it out myself just to be sure and, guess what: You're 100%
>> right - with no write permissions in the eclipse installation folder
>> the platform will not start and you get bombarded with exceptions!
>> Poor show for eclipse here, I'm afraid (unless someone else knows a
>> workaround).
>> One workaround I can think of myself is to install eclipse into your
>> home directory.
> This is exactly what I happened to do - it this uncommon/discouraged?
> Does it make more sense to go someplace like /opt? What's the rationale?
>>> Hi,
>>> Have you tried launching eclipse with the -data parameter? Something
>>> like:
>>> /opt/eclipse/eclipse -data /home/<your name>/<your development
>>> directory>
>>> This will create an eclipse workspace under <your development
>>> directory> in your home directory. Should work!
>>>> Hi,
>>>> I started today with eclipse on Linux. I found out that you have to
>>>> have write permission on the installation folder and configuration
>>>> folder.
>>>> This is really WEAK! All user related data should be stored in the
>>>> HOME of
>>>> the user. :-(
>>>> But may be Eclipse is only a tool for Windows users.
>>>> Ciao
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the FAQ at http://www.eclipse.org/webmaster/faq.html
View my status at http://www.eclipse.org/webmaster/main.html
Re: linux - root vs. standard user [message #29861 is a reply to message #29833] |
Thu, 03 March 2005 17:27  |
Originally posted by: muhammad.dwyer.gmail.com
Thanx WebMaster,
That more or less resolves this issue completely. For that matter, is their
a FAQ for this type of issue, outside of the bug database?
FUDForum. Page generated in 0.31703 seconds
