Multiple palette tool elements for one domain model node [message #180327] |
Wed, 02 April 2008 05:43  |
I have an element A that can contain several elements B. I would like to
distinguish B elements : B0 and B1. B0 and B1 are domain model B
elements but they will be intialize differently. So, in my palette tool,
I would like to have 2 different items : B0 and B1.
My .gmftool contains :
B0 item
B1 item
My .gmfmap contains :
NODE A
Compartment BElements
Child Reference
NODE B ---> B0 item tool
Child Reference
NODE B ---> B1 item tool
When I launch my diagram, the palette tool effectively contains 2
different items. One item correctly creates a B element, but the other
throws an error when I want to create the element on my compartment :
org.eclipse.core.commands.ExecutionException: While executing the
operation, an exception occurred
I suppose that I have to modify my .gmfgen file... but I don't know
where and what ....
I have an other question : I would like to display a different
properties view content according the type of my Element B : how can I
do that ? (which are functions to change ? Where...)
Thanks for your help!
Philippe
Here is my error detail :
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:519)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:205)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:168)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:155)
at org.eclipse.gef.tools.AbstractTool.executeCommand(AbstractTo ol.java:388)
org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(Abs tractTool.java:400)
org.eclipse.gmf.runtime.diagram.ui.tools.CreationTool.perfor mCreation(CreationTool.java:133)
at org.eclipse.gef.tools.CreationTool.handleButtonUp(CreationTo ol.java:178)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java :1053)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:259)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Released(DomainEventDispatcher.java:374)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(Li ghtweightSystem.java:538)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:206)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Caused by: org.eclipse.jface.util.Assert$AssertionFailedException: null
argument;failed to create a view
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:153)
org.eclipse.gmf.runtime.diagram.ui.commands.CreateCommand.do ExecuteWithResult(CreateCommand.java:99)
org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand.doExecute(AbstractTransactionalCommand.ja va:246)
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:137)
org.eclipse.gmf.runtime.common.core.command.CompositeCommand .doExecuteWithResult(CompositeCommand.java:403)
org.eclipse.gmf.runtime.common.core.command.AbstractCommand. execute(AbstractCommand.java:134)
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
... 37 more
Re: Multiple palette tool elements for one domain model node [message #180520 is a reply to message #180388] |
Wed, 02 April 2008 11:39  |
Arf, you are right Alex.
Tutorial 2 says : "In fact, whenever you create multiple mappings to a
single domain element, you will need to add constraints such that each
can be uniquely identified.".
Thank you very much !
Alex Shatalin a écrit :
> Hello Philippe,
>> to distinguish B elements : B0 and B1. B0 and B1 are domain model B
> Just one addition: to correctly model this situation in GMf you should
> create
> not only two ChildReference/NodeMappings for B0 and B1 - you have to add
> corresponding initializer/OCL constraint for each of these Mappings.
> Proper OCL constraints absence can be the reason for an exception.
> Alex Shatalin
FUDForum. Page generated in 0.07595 seconds
