Problem running JUnit tests [message #180302] |
Wed, 15 November 2006 05:49  |
Originally posted by: mboeckling.heiler.com
Hi!
I have a problem running unit-tests in Eclipse (3.2).
The tests are relatively simple, they don't need any special Eclipse
internals to execute.
The tests are in a seperate /test source folder in the plugin.
The project is a plugin project, but running the tests as "JUnit plugin
tests" brings up the same error message.
I tried putting the test packages in the "exported packages" section in the
manifest, but that didn't help.
I have the following entries in my manifest classpath:
Bundle-ClassPath: .,
src/,
test/
What could be wrong? Below is the stacktrace of a sample test that I get
when I try to run it.
Thank you,
Michael Böckling
Class not found
com.heiler.ppm.cms.core.impl.rql.api.commands.page.ListStruc turalElementsTest
java.lang.ClassNotFoundException:
at java.net.URLClassLoader$1.run(URLClassLoader.java:199)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
at java.lang.ClassLoader.loadClass(ClassLoader.java:289)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:274 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadC lass(RemoteTestRunner.java:683)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadC lasses(RemoteTestRunner.java:425)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:445)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Re: Problem running JUnit tests [message #180408 is a reply to message #180302] |
Wed, 15 November 2006 14:38  |
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
Michael Böckling wrote:
> Hi!
> src/,
> test/
> Thank you,
> Michael Böckling
Is the /test folder configured to be a Java source file? i.e. does it
have a little icon with a folder/package picture?
Wayne
FUDForum. Page generated in 0.20626 seconds
