Home » Modeling » M2T (model-to-text transformation) » Using AND in a test
Using AND in a test [message #17003] Mon, 21 May 2007 06:29 Go to next message
Originally posted by: evaandoli.dodo.com.au
Can you use 'and' type statement in a test
eg.
<c:choose>
<c:when test="$myVar/@kind = 'FIELD' AND $myVar/@kind2 = 'TEXT'">
content to process if test condition is satisfied
</c:when>
.... other <c:when> and <c:otherwise> tags ...
</c:choose>
if so what is the syntax.
Re: Using AND in a test [message #17035 is a reply to message #17003] Tue, 22 May 2007 08:27 Go to previous message
Stu:
The proper conjunction is 'and'. I just re-read the XPath spec to see
whether the parser should be doing a case-insensitive compare. Here's all I
have to go on:
http://www.w3.org/TR/xpath#NT-AndExpr
I have interpreted the omission of any discussion on case-insensitivity to
mean that the parser should match 'and' only. If you feel the parser should
be case insensitive on this (and other keywords, such as 'or'), please
submit an enhancement bugzilla.
Paul
"Stu" <evaandoli@dodo.com.au> wrote in message
news:f2rsb5$4e0$1@build.eclipse.org...
> eg.
> <c:choose>
> </c:when>
> </c:choose>
Previous Topic:Jet : define recursive fonction.
Next Topic:Trying to use count() on subset of nodes
Current Time: Thu Jul 17 20:08:59 EDT 2025
Powered by FUDForum. Page generated in 0.05378 seconds
