P6Spy and hibernate synchronizer [message #179950] |
Tue, 14 November 2006 10:20 |
Originally posted by: jmagresta.tiscali.fr
Hello
New to eclipse , i have some problems with Hibernate synchronizer while
ving mapping information from ingres 2.5 .
When doing in a mapping on a database with 100+ tables, the resulting
mapping containes table names but no fields.
In order to analyze this problem, i tried to install PSPY in order to
check what data were exchanged between Eclipse/HibernateSynchronizer and
Ingres and were lay the problem.
So i configure P6spy as the database driver and the psy.properties
accordingly .
But when doing a refresh in the Hiberbate mapping in Eclipse/Hiberbate
synchronizer, the following message is displayed
database driver found ( approximate message)
spy.properties not found in classpath.
I tried to locate the spy.properties file in different place :
with the p6spy.jar folder
within the eclipse project classpathes folder
within the hibernate folder
within the JAVA_HOME/jre/lib/ext
But to no avail.
Does sombody have an expérience tracing hibernate/synchronizer sql
requests with p6spy ( or any other tools).
Thanks in advance.
J.M. Agresta
FUDForum. Page generated in 0.07613 seconds
