Home » Eclipse Projects » GEF » Cannot select/move/resize EditParts directly
Cannot select/move/resize EditParts directly [message #179756] Fri, 29 April 2005 20:20 Go to next message
Originally posted by: d.ozsen.blueyonder.co.uk
Hi there,
I have a problem with the selection/moving/resizing of EditParts in my
GEF editor. My EditPart and Figure structures are fairly simple, but the
main container EditPart that contains the objects I want to be able to
move around/resize/delete etc. is nested in another couple of components
which are fixed and only change in size and appearance according to some
properties in the model (and this works perfectly).
My problem is that even though I have installed my own EditPolicy for
the LAYOUT_ROLE in my container I cannot select/move/resize the
components within this container - at least not directly. It does work
when I drag a selection box from somewhere far outside the said
container into the container and enclose one or more of the container's
components in that selection box. Then they are selected, show the
expected selection handles and I can even move and resize them (showing
that my controller is listening to model changes properly and my
EditPolicy is at least doing something right) - however this only works
if I drag the selection handles, if I try to drag an object by its
centre, it does not work. Even when an object is in a selected state and
I single-click it by its centre it becomes unselected.
Does anybody have an idea as to what this could be?? I'd be grateful for
any help!
Deniz
Re: Cannot select/move/resize EditParts directly => solved [message #179764 is a reply to message #179756] Fri, 29 April 2005 20:47 Go to previous message
Sorry to have you read this long text, if anyone did...
I have just found that my suspicions were right: I have done something
very, very stupid. Basically my model was populated with a lot of
complicated data, which resulted in some transparent Figures being
created on top of the components that I wanted to move (I haven't
implemented some of the other component types properly yet). And so my
mouse clicks were intercepted by those other Figures, hence the problem
with their selection, movement etc.
D
Deniz Ozsen wrote:
> Hi there,
> any help!
> Deniz
Previous Topic:Clickable in a Draw2D figure
Next Topic:Re: Changing the size of scrollbar
Current Time: Mon Jul 14 09:53:15 EDT 2025
Powered by FUDForum. Page generated in 0.28315 seconds
