Home » Eclipse Projects » Subversive » Repository Location on a FileServer
Repository Location on a FileServer [message #16967] Wed, 23 April 2008 05:49 Go to next message
Hi all,
i'm new to subversive, but not to subversion. I want to create a access to
an existing Repository, which lies on a FileServer. Unfortunately, this
subversion is not combined with apache, so that i have to use the
file-Protocol.
That's the problem: Every time i enter the url
file:///\\fileserver\some_path, subversive looks a
d:\...\fileserver\some_path for the repository.
Can someone help me?
Thx
Timothy
Re: Repository Location on a FileServer [message #17056 is a reply to message #16967] Wed, 23 April 2008 22:17 Go to previous messageGo to next message
I know this is not a solution, but as a temporary workaround, you could map
your SMB server directory to a local drive (e.g. X:\) and then access it via
file://x/some_path
I am not sure about the exact format of the file:// URL in this case and I
am not on Windows right now to try it but I think it would work since as far
as subversion is concerned at this point x:// should be a perfectly normal
local drive.
On 23.04.2008 16:49, in article fun0nd$c4e$2@build.eclipse.org, "Timothy
Marc" <timothymarc@freenet.de> wrote:
Hi all,
file-Protocol.
Thx
Timothy
Re: Repository Location on a FileServer [message #17086 is a reply to message #17056] Thu, 24 April 2008 02:26 Go to previous message
Originally posted by: Marko.Schulz.gmail.com
"Nik Heger" <nheger@gmail.com> schrieb im Newsbeitrag
news:C43600AC.682%nheger@gmail.com...
> map
> via
> file://x/some_path
According to the subversion docs a drive letter is mandatory on windows. The
correct syntax for that is also explained there:
http://svnbook.red-bean.com/en/1.0/ch02s03.html#svn-ch-2-sid ebar-1
(This section was slightly rewritten in later editions of the docs, see e.g.
http://svnbook.red-bean.com/en/1.4/svn.basic.in-action.html)
marko
Previous Topic:switch project to another svn repository
Next Topic:Ignoring resources from Version Control
Current Time: Sat Jun 07 15:37:09 EDT 2025
Powered by FUDForum. Page generated in 0.02876 seconds
