Home » Language IDEs » ServerTools (WTP) » Tomcat 5.5 - 404 errors when running in Eclipse
Tomcat 5.5 - 404 errors when running in Eclipse [message #179587] Thu, 21 September 2006 15:58 Go to next message
Originally posted by: curtc.tmscorp.com
Greetings - I've just installed the lastest eclipse, and following the
eclipse docs, added a Tomcat server to the server list, as well as a web
application. I can start TomCat 5.5 on winxp just fine outside of eclipse,
and connect to port 8080 & get default pages, but when I connect to the
tomcat started in eclipse enviroment, tomcat returns 404 not found for any
page I select.
I know this is a basic question, but any advice would be most appreciated.
Curt.
Re: Tomcat 5.5 - 404 errors when running in Eclipse [message #179606 is a reply to message #179587] Thu, 21 September 2006 16:19 Go to previous message
It looks like the following recent post ("Re: problem loading
localhost:8080 in eclipse" on 9/20) might apply:
http://dev.eclipse.org/newslists/news.eclipse.webtools/msg12 103.html
Larry
> eclipse, and connect to port 8080 & get default pages, but when I
> connect to the tomcat started in eclipse enviroment, tomcat returns 404
> not found for any page I select.
> Curt.
Previous Topic:Problem with Project Facet
Next Topic:duplicating some functionality in Create XML File wizard
Current Time: Sat Jul 26 07:40:46 EDT 2025
Powered by FUDForum. Page generated in 0.23472 seconds
