Home » Language IDEs » C / C++ IDE (CDT) » standard vs managed make project and gdb differences
standard vs managed make project and gdb differences [message #179479] Thu, 09 November 2006 12:37 Go to next message
Originally posted by: shawn.protsman.patownsend.com
This may be a configuration issue on my part. I've created a Managed Make
C with the following test app:
1 #include <stdio.h>
2 int main(int argc, char **argv)
3 {
4 int idx = 0;
5 for (idx = 0; idx < 10; ++idx)
6 (void)printf("foo <%2d>\n", idx);
7 return 0;
8 }
I run it through debug within CDT and everything works just fine. If I
create a new Standard Make C project with the same code as above and run
it through the debugger (verbose mode) it doesn't work correctly. It will
pass right by any breakpoint. The CDT console reports:
153-break-insert foo.c:6
&"No source file named foo.c.\n"
153^done
(gdb)
154-break-insert -t main
154^done,bkpt={number="1",type="breakpoint",disp="del",enabled= "y",addr="0x080483b4",at="<main>",times="0"}
(gdb)
<snip>
~"Program stopped at 0xb7f12ff0.\n"
~"It stopped at a breakpoint that has since been deleted.\n"
You see, it reports that it cannot find the file named foo.c which is
rather odd. This explains why it just seems to ignore the breakpoint. This
works fine with Managed but not with Standard so that led me to believe
I've got a configuration setting/issue that I'm unaware of when using
Standard Make projects. Any help will be greatly appreciated!
Platform information:
SUSE Linux Enterprise Desktop 10 (i586)
Java version "1.5.0_06"
Eclipse 3.2.1
CDT 3.1.1
gdb-6.4-19.10
gcc (GCC) 4.1.0 (SUSE Linux)
Re: standard vs managed make project and gdb differences [message #179567 is a reply to message #179479] Mon, 13 November 2006 15:52 Go to previous messageGo to next message
Anyone experience this? We would like to use Eclipse with CDT to develop
enterprise software for linux but this is becoming a problem when we
cannot even use Standard Make Projects.
Re: standard vs managed make project and gdb differences [message #179575 is a reply to message #179567] Mon, 13 November 2006 17:30 Go to previous message
Ha, I overlooked the fact that I wasn't adding any debug flags (-g) in my
Makefile when using a Standard Make Project. Total oversight on my part!
Previous Topic:Terminating out of run leaves .exe file busy
Next Topic:Is there any plugin that allow remote compile?
Current Time: Fri Jul 18 05:43:19 EDT 2025
Powered by FUDForum. Page generated in 0.07493 seconds
