Home » Modeling » M2T (model-to-text transformation) » Trying to use count() on subset of nodes
Trying to use count() on subset of nodes [message #16941] Fri, 18 May 2007 17:01 Go to next message
Originally posted by: bernard.farrell.gmail.com
I have a set of nodes like the following:
<page name="AtionName">
<form action="dataForm">
<label type="field" name="description">
<input type="textarea" />
</label>
<label type="field" name="startdate">
<input type="dateselector" required="false"/>
</label>
</form>
</page>
And I'm trying to output code if any of the nodes have the type set to
'textarea'.
I wanted to use the count() function, but before I even get there, using
square brackets seems to choke the system.
<cc:setVariable select="$page/form/label/input/[@type='textarea']"
var="tfields" />
<cc:setVariable select="count($tfields)" var="numfields" />
I get an unrecognized token '[' on the first line above. It's two lines
because the expression in the first line seems to cause an error when
enclosed in the count() on the second line.
Now later in the same file I'm using this expression:
<cc:iterate select="$page/form/label[@type='field']" var="field">
with no problem.
What am I doing wrong here?
Re: Trying to use count() on subset of nodes [message #17094 is a reply to message #16941] Tue, 22 May 2007 10:09 Go to previous messageGo to next message
Bernard:
Sometimes the simplest solutions elude you - I looked at this for 30 minutes
before seeing it :-).
Your first XPath expression should be:
$page/form/label/input[@type='textarea']
(Note the slash was removed after 'input'.)
Paul
"Bernard Farrell" <bernard.farrell@gmail.com> wrote in message
news:2400e9deed69d5b16844e82b6653b405$1@www.eclipse.org...
> </label>
> </label>
> </form>
> </page>
> 'textarea'.
> var="tfields" />
> with no problem.
Re: Trying to use count() on subset of nodes [message #17123 is a reply to message #17094] Tue, 22 May 2007 16:38 Go to previous messageGo to next message
Paul
Thanks, we figured that out here yesterday. A fresh set of eyes helped a
lot. It would be great if there was an article (I'm thinking of writing
one myself) that shows how to solve common JET templating challenges with
sample expressions.
In the end, I just wrote the expression as:
<cc:if test="$page/form/label/input[@type='textarea']">
which a colleague pointed out worked (for my purposes) just as easily as:
<cc:if test="count($page/form/label/input[@type='textarea']) > 0">
(And I'm using cc: because the tags are in a .jsp template file.
Bernard
Paul Elder wrote:
> Bernard:
> Paul
>> </label>
>> </label>
>> </form>
>> </page>
>> 'textarea'.
>> var="tfields" />
>> with no problem.
Re: Trying to use count() on subset of nodes [message #17152 is a reply to message #17123] Wed, 23 May 2007 08:17 Go to previous message
Bernard:
Glad you solved this. Once the Europa release is out of the way, I'm
thinking of starting a JET FAQ.
I'll post an announcement to the newsgroup once I've got the infrastructure
in place.
Paul
news:94814c63aec2f9c2f591a3f10489dd62$1@www.eclipse.org...
> Paul
> sample expressions.
> Bernard
> Paul Elder wrote:
>> Bernard:
>> minutes before seeing it :-).
>> Paul
>>> </label>
>>> </label>
>>> </form>
>>> </page>
>>> 'textarea'.
>>> var="tfields" />
>>> with no problem.
Previous Topic:Using AND in a test
Next Topic:Code generation for the UML
Current Time: Sun May 25 03:31:48 EDT 2025
Powered by FUDForum. Page generated in 0.05737 seconds
