Struts Error [message #179266] |
Thu, 09 November 2006 19:55 |
Originally posted by: bhagirath.patel.va.gov
Hi there..
this is what the error appears when I try to run my Struts Web
Application with TOmcat and Eclipse 3.2...Any idea ????
type Exception report
message
description The server encountered an internal error () that prevented it
from fulfilling this request.
exception
org.apache.jasper.JasperException: Failed to load or instantiate
TagExtraInfo class: org.apache.struts.taglib.logic.IterateTei
org.apache.jasper.compiler.DefaultErrorHandler.jspError(Defa ultErrorHandler.java:50)
org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDis patcher.java:411)
org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDis patcher.java:283)
org.apache.jasper.compiler.TagLibraryInfoImpl.createTagInfo( TagLibraryInfoImpl.java:422)
org.apache.jasper.compiler.TagLibraryInfoImpl.parseTLD(TagLi braryInfoImpl.java:248)
org.apache.jasper.compiler.TagLibraryInfoImpl.<init>(TagLibraryInfoImpl.java:162)
org.apache.jasper.compiler.Parser.parseTaglibDirective(Parse r.java:418)
org.apache.jasper.compiler.Parser.parseDirective(Parser.java :483)
org.apache.jasper.compiler.Parser.parseElements(Parser.java: 1539)
org.apache.jasper.compiler.Parser.parse(Parser.java:126)
org.apache.jasper.compiler.ParserController.doParse(ParserCo ntroller.java:220)
org.apache.jasper.compiler.ParserController.parse(ParserCont roller.java:101)
org.apache.jasper.compiler.Compiler.generateJava(Compiler.ja va:203)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:47 0)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:45 1)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:43 9)
org.apache.jasper.JspCompilationContext.compile(JspCompilati onContext.java:511)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:295)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:292)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :236)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
Please let me know...
Thanx in advanced..
Re: Struts Error [message #179290 is a reply to message #179266] |
Thu, 09 November 2006 20:48 |
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
Bhagirath wrote:
> Hi there..
> message
> it from fulfilling this request.
> exception
> Thanx in advanced..
Are you missing a required library?
This doesn't sound like an Eclipse problem. Maybe somebody on this list
can help you, but you'll likely get a better answer on a Struts forum.
Wayne
FUDForum. Page generated in 0.08110 seconds
