Re: Wrong positioning of figures if editor is scrolled [message #179332 is a reply to message #179302] |
Tue, 26 April 2005 11:38   |
Ahh, I found the problem. getCreateCommand(final CreateRequest request) in
my subclass of
XYLayoutEditPolicy was:
protected Command getCreateCommand(final CreateRequest request)
if (request.getNewObjectType() == State.class)
return new StateCreateCommand(workflow,
(State)request.getNewObject(),request.getLocation().x,
request.getLocation().y);
else if (request.getNewObjectType() == Transition.class)
return new TransitionCreateCommand(workflow,
(Transition)request.getNewObject(), request.getLocation().x,
else return null;
It took x and y directly from the request without converting them to
relative coordinates.
Now it does it like this:
Rectangle constraint = (Rectangle)getConstraintFor(request);
(State)request.getNewObject(),constraint.x, constraint.y);
(Transition)request.getNewObject(), constraint.x, constraint.y);
else return null;
This works better. Thank you very much Randy!
"Randy Hudson" <none@us.ibm.com> schrieb im Newsbeitrag
news:d4lj8m$q0n$1@news.eclipse.org...
> Normally XYLayoutEditPolicy will convert the absolute location of the
> request ot a relative constraint. Perhaps you've overridden a method and
> gotten rid of the conversion?
> "Roger Villars" <roger.villars@mimacom.ch> wrote in message
> news:d4l3v9$3rt$1@news.eclipse.org...
>> Hi!
>> I have a problem with the positioning of figures when they are created
>> with the palette.
>> If my editor pane is bigger than the viewable region and is scrolled,
>> then my figures aren't placed at the right position (the position of the
>> mouse cursor). They are shifted by the amount by which the editor is
>> scrolled (see picture).
>> I think there's a problem with absolute and relative coordinates. Any
>> suggestions what I'm doing wrong?
>> Roger
Connections too - Wrong positioning of figures if editor is scrolled [message #179975 is a reply to message #179332] |
Mon, 02 May 2005 09:10  |
Originally posted by: binti.ksu.edu
Hey Roger and others,
Unless I read your mail, I never knew this problem was in my tool too. But
Thanks, I found it and solved it too.
But still the connections have the same problem. I have my own anchor class
which returns a location where the connection needs to be created, it takes
this position from the request (Create Request) and reconnect request when I
try moving it. The code for this is in NodeEditPoliciy for the nodepart. I
do not have a getConstraintFor() method there.
Could anybody tell me how do I handle this here?
Binti.
news:d4lne7$180$1@news.eclipse.org...
> my subclass of
> else return null;
> else return null;
>>> Hi!
>>> with the palette.
>>> Roger
FUDForum. Page generated in 0.33438 seconds
