Re: How to set up a CVS at SourceForge ? [message #179210 is a reply to message #179165] |
Thu, 09 November 2006 14:11 |
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
Tintin92 wrote:
> Hello,
> Location Host : ?????????
> Repository path : ??????
> Etc....
The source forge project should give you this sort of information.
For example, the Eclipse Mahjong project can be connected to via CVS
with instructions at:
http://sourceforge.net/cvs/?group_id=172358
I found this by clicking the "Code > CVS" link.
On that page, it tell me to set
Location Host: eclipse-mahjong.cvs.sourceforge.net
Repository Path: /cvsroot/eclipse-mahjong
etc.
Of course, this assumes that the project is CVS-enabled. I believe that
Source Forge now does Subversion on some projects, so you'd need to get
a Subversion plug-in to access these.
If you want to set up a Source Forge project to provide CVS access,
you'll have to follow the instructions on the Source Forge site.
Wayne
Re: How to set up a CVS at SourceForge ? [message #179277 is a reply to message #179210] |
Thu, 09 November 2006 20:05 |
Originally posted by: no.spam.com
> > Hello,
> > Etc....
> > Thanks,
> etc.
Hello Wayne,
Try the Eclipse Mahjong project but ask me a password.
I press the Enter key. But it dont work.
Here a image :
http://cjoint.com/?lju4mAIRIs
Any other idea ?
The projet I try to download the source is :
http://sourceforge.net/projects/sfljtse/
But I think is the same thing.
Tintin92
> Wayne
Re: How to set up a CVS at SourceForge ? [message #179305 is a reply to message #179277] |
Thu, 09 November 2006 20:53 |
Tintin92 wrote:
>>>Hello,
>>>Etc....
>>>Thanks,
>>etc.
> Hello Wayne,
> Here a image :
> Any other idea ?
> Tintin92
>>Wayne
Apparently I picked a bad project. For some reason, anonymous pserver
access doesn't work against this project. I tried it with another
project and it worked fine.
http://sourceforge.net/cvs/?group_id=166350
I'll talk to the Mahjong project's owner about fixing it.
In the meantime, it seems that the problem doesn't lie in Eclipse, but
rather in how the project is configured on Source Forge.
Are you having trouble with a particular project?
Wayne
FUDForum. Page generated in 0.06207 seconds
