Re: is it possible for me to replace the palette with menu [message #17055 is a reply to message #17027] |
Mon, 19 August 2002 09:17  |
Originally posted by: hudsonr.spam.com
Is the user able to position nodes in your application? If so, there is no
mouse location information when the context menu appears (Shift+F10 invokes
context menu also). On creation, how would you know where to create the
node?
Anyway, there is some documentation in the integrated help. You might look
at CreateRequest, and your action could extend SelectinAction, and only
enable when the correct parent is the only selected part.
"netbeans" <bkandan@selectica.com> wrote in message
news:ajqi8p$c05$1@rogue.oti.com...
> hi,
> does anyone know where i can find a detailed documentation for GEF...as
> iam find it difficult to learn from the logic example....
> i am tryin to create an xml editor using gef...unlike the visio which uses
> drag and drop mechanism for adding nodes, i want to let the user right
click
> any node and say add node or something like that, so that the user need
not
> draw connectors between nodes...
> this is what i am trying to achieve...
> thanks in advance...
> Balaji
> news:ajl7oj$l7v$1@rogue.oti.com...
> > hi all,
> > i am trying to replace the palette with popup menu
> > in my application...is it possible..if so how can i achieve it?
> > Balaji...
FUDForum. Page generated in 0.07887 seconds
