Home » Modeling » GMF (Graphical Modeling Framework) » GMF-based diagram editor using an extension of uml2 meta-model.
GMF-based diagram editor using an extension of uml2 meta-model. [message #179083] Wed, 26 March 2008 07:22 Go to next message
Originally posted by: fatma.krichen.gmail.com
Hello
I want to create an GMF-based diagram editor using an extension of uml2
meta-model.
I already create this editor, but the problem is only the new extended
elements did not appear in the draw screen (it appear correctly in XMI
file)
Problems :
"Could not restore workbench layout.
Reason:
Problems occurred restoring workbench."
Details
"Unable to restore perspective: Workspace - Java.
Internal error activating an Editor.
extension/ExtensionPackage"
Re: GMF-based diagram editor using an extension of uml2 meta-model. [message #179278 is a reply to message #179083] Wed, 26 March 2008 12:45 Go to previous message
hello,
I extend the uml2 meta-model, I can't add an element to screen in
GMF-based diagram editor .
Please can you explain what means : Children Feature and Children Feature
in gmfmap file?
Please can you explain what means : Children Feature and Containment
Feature in gmfmap file? I believe that is the problem.
thank you
Previous Topic:figure inside of two figures
Next Topic:Edge creation
Current Time: Tue Dec 02 13:52:00 EST 2025
Powered by FUDForum. Page generated in 0.03228 seconds
