Home » Archived » BIRT » Using request in setAppContext of jdbcbridge
Using request in setAppContext of jdbcbridge [message #179019] Thu, 20 July 2006 04:23
Hello all,
I used the jdbcbridge (old subOdaJdbcBridge).
The appContext method have to be done, if i launch the report thru a webApp or thru eclipse.
My problem is that the launcher can be from another webapp (could also be an executable that launch IE).
So I have to take connection parameters into the parameters/attributes of the request.
So my jdbcbridge has into the method setAppContext :
Object req = ((HashMap)context).get(EngineConstants.APPCONTEXT_BIRT_VIEWE R_HTTPSERVET_REQUEST);
HttpServletRequest request = (HttpServletRequest)req;
The classpath of myjdbcbridge has an entry for an external servlet.jar.
If i add the plugin to platform/plugins of my webapp, it works fine.
But if i add this plugin to eclipse and run it, the class loader doen't know any servlet.jar.
Bingo ... ClassCastException : NoClassDefFoundError on the line that cast req to request.
So in the manifest of my plugin, I add an entry for a dependency with org.eclipse.tomcat
but i still need servlet.jar because org.eclipse.tomcat is restricted, so the execution fails in the same way.
In fact, if someone can told me how to know that i'm running into eclipse with the reportContext,
I wouldn't have the need to acces to HttpServletRequest ...
Thanks a lot for any suggestions !!!
Thibaud
Previous Topic:Problem with ODA-Plugin in Version 2.1
Next Topic:Round to 2nd decimal
Current Time: Wed Nov 19 04:52:52 EST 2025
Powered by FUDForum. Page generated in 0.03701 seconds
