Home » Eclipse Projects » Subversive » switch project to another svn repository
switch project to another svn repository [message #16880] Tue, 22 April 2008 12:33 Go to next message
we may have to change svn repository (a new one will be created on a new
machine etc but with the same projects).
is it possible to disconnect from repo1 and reconnect to repo2 -
therefore not losing any changes one has made locally and not committed
yet ?
Edoardo
Re: switch project to another svn repository [message #16910 is a reply to message #16880] Wed, 23 April 2008 00:05 Go to previous message
Yes. Use svn switch on the command line, you want option (2) below
$>svn --help switch
switch (sw): Update the working copy to a different URL.
usage: 1. switch URL [PATH]
2. switch --relocate FROM TO [PATH...]
1. Update the working copy to mirror a new URL within the repository.
This behaviour is similar to 'svn update', and is the way to
move a working copy to a branch or tag within the same repository.
2. Rewrite working copy URL metadata to reflect a syntactic change only.
This is used when repository's root URL changes (such as a scheme
or hostname change) but your working copy still reflects the same
directory within the same repository.
Valid options:
-r [--revision] arg : ARG (some commands also take ARG1:ARG2 range)
A revision argument can be one of:
NUMBER revision number
'{' DATE '}' revision at start of the date
'HEAD' latest in repository
'BASE' base rev of item's working copy
'COMMITTED' last commit at or before BASE
'PREV' revision just before COMMITTED
-N [--non-recursive] : operate on single directory only
-q [--quiet] : print as little as possible
--diff3-cmd arg : use ARG as merge command
--relocate : relocate via URL-rewriting
--username arg : specify a username ARG
--password arg : specify a password ARG
--no-auth-cache : do not cache authentication tokens
--non-interactive : do no interactive prompting
--config-dir arg : read user configuration files from directory
ARG
On 22.04.2008 23:33, in article ful40f$kjc$2@build.eclipse.org, "Edoardo
yet ?
Edoardo
Previous Topic:Subversive History Extremely Slow
Next Topic:Repository Location on a FileServer
Current Time: Thu Jul 10 01:04:42 EDT 2025
Powered by FUDForum. Page generated in 0.03231 seconds
