Home » Archived » Maven Integration (M2E) » running tomcat under elipse when using m2eclipse
running tomcat under elipse when using m2eclipse [message #16879] |
Wed, 01 October 2008 17:04  |
Originally posted by: rusty.berkeley.edu
In my pom.xml file, in its properties section, I'm setting various
properties that are common to all builds, but which can be overridden in
profiles. I consider these my default properties.
In my profiles, in profiles.xml, I'm setting some properties that aren't
in the pom.xml because they're different for each profile.
My Spring configuration files are in src/main/resources.
When maven does the goal process-resources it copies those files to the
following directory and replaces the ${} placeholders, which is what the
tomcat that runs under eclipse uses:
<workspace> /.metadata/.plugins/org.eclipse.wst.server.core/tmp0/wtpweba pps/ <my_app>/WEB-INF/classes
But it doesn't do the replacement for the properties that are only set
in the profiles.
As far as I can tell maven doesn't have a default profile so it seems to
me that my only options are to add these non-default properties to my
default properties, or to use the activation by the absence of a
property feature (section 11.3.2 in the Sonatype Definitive Guide).
Are there other (preferred?) alternatives I'm overlooking?
Re: running tomcat under elipse when using m2eclipse [message #16909 is a reply to message #16879] |
Wed, 01 October 2008 17:29   |
Rusty,
You need to specify profiles that you want to be active on the Maven
properties page for your project. Also, you can specify what profiles
need to be activated by default in settings.xml, or declare activation
rules based on the presence of some system property.
For activation rules you can use system properties specific to Eclipse
(e.g. "eclipse.buildId", see more in Help / About Eclipse SDK /
Configuration Details), or add your own properties (-Dfoo=value) in
eclipse.ini or in Eclipse command line. Though please note that those
system properties are not inherited by the Maven process launched from
Run as... / Maven actions and you'll need to specify profile explicitly
in the Maven launch configuration dialog.
regards,
Eugene
> in profiles. I consider these my default properties.
> aren't in the pom.xml because they're different for each profile.
> the following directory and replaces the ${} placeholders, which is
> what the tomcat that runs under eclipse uses:
> in the profiles.
> to me that my only options are to add these non-default properties to
> my default properties, or to use the activation by the absence of a
Re: running tomcat under elipse when using m2eclipse [message #16938 is a reply to message #16909] |
Wed, 01 October 2008 19:05   |
"You need to specify profiles that you want to be active on the Maven
properties page for your project."
Excellent; thanks, that's what I was looking for. I didn't think to
look there. I was looking in preferences.
Eugene Kuleshov wrote:
> Rusty,
> regards,
> Eugene
>> in the profiles.
Re: running tomcat under elipse when using m2eclipse [message #16968 is a reply to message #16938] |
Wed, 01 October 2008 19:10   |
For the future reference, there is a documentation on the wiki for
that. http://docs.codehaus.org/display/M2ECLIPSE/Dependency+Manage ment
Actually, we could use some help from the community to expand
documentation on the wiki. So, by all means, please feel free to edit
anything that need to be clarified or improved.
Eugene
>> Rusty,
>> activation rules based on the presence of some system property.
>> Eclipse (e.g. "eclipse.buildId", see more in Help / About Eclipse SDK
>> / Configuration Details), or add your own properties (-Dfoo=value) in
>> from Run as... / Maven actions and you'll need to specify profile
>> explicitly in the Maven launch configuration dialog.
>> regards,
>> Eugene
>>> overridden in profiles. I consider these my default properties.
>>> set in the profiles.
>>> seems to me that my only options are to add these non-default
>>> properties to my default properties, or to use the activation by the
>>> absence of a property feature (section 11.3.2 in the Sonatype
>>> Definitive Guide).
Re: running tomcat under elipse when using m2eclipse [message #17029 is a reply to message #16968] |
Fri, 03 October 2008 16:07   |
On the wiki, for Active Maven Profiles it says "If specified, dependencies from these profiles will be picked up." Does that mean it only uses the profile I put there for resolving dependencies or will it use that profile for anything and everything it could affect; for example, setting properties?
I'm confused because in my project's properties, under Maven, I have localhost-postgres specified for the Active Maven Profiles. In Eclipse's Run menu I have a run configuration named active-profiles, and the Goals box contains help:active-profiles and the Profiles: box is empty, and when I run that, in the Eclipse console window it doesn't list any active profiles.
> Thanks
> Eugene
>>> Rusty,
>>> regards,
>>> Eugene
>>>> Definitive Guide).
Re: running tomcat under elipse when using m2eclipse [message #17091 is a reply to message #17029] |
Fri, 03 October 2008 16:35   |
I suppose text on the wiki is bit confusing. We don't do anything
special with specified profiles, just make them active, so maven would
use them for anything.
Note that there is several cases when Maven is launched:
* dependency resolution
* maven project builder
* launch maven from Run/Debug menu
The first one is using profiles specified in the project preferences
and I am almost certain that builder is also using those. Predefined
actions like "Run As... / Maven package" don't use those profiles now,
but there is a jira issue for that, please vote there.
http://jira.codehaus.org/browse/MNGECLIPSE-895
I don't think it would be appropriate to implicitly add project's
profiles into the general Maven launch configuration UI, so when
"profiles" field is empty help:active-profiles is not supposed to show
anything (unless you activate those profiles automatically based on some
properties or other conditions), but please feel free to comment on that
in MNGECLIPSE-895.
regards,
Eugene
Re: running tomcat under elipse when using m2eclipse [message #17149 is a reply to message #17091] |
Fri, 03 October 2008 17:39  |
Ah, I see. Thanks.
I added a jira comment suggesting adding a check box specifying to force adding the profile in the Properties when you use a Run/Debug configuration.
> in MNGECLIPSE-895.
> regards,
> Eugene
Current Time: Wed Jul 16 16:23:07 EDT 2025
Powered by FUDForum. Page generated in 0.07960 seconds
