problem with subversive [message #178395] |
Sun, 05 November 2006 07:01 |
Originally posted by: maosen.zhang.alibaba-inc.com
I intall subversive in my eclipse3.2.
When I check project using svn project in eclipse, I have some problems:
1 use subversive to download java project (Hadoop)
2 proceed to select 'create new java project' then 'finish'
but the project(Hadoop)created by eclipse is not a java project, I cant't
build the whole project at all.
Do you have some thoughts? Thank you !
Re: problem with subversive [message #178473 is a reply to message #178395] |
Mon, 06 November 2006 02:18 |
Was the Java project (Hadoop) created using Eclipse? Does it have a
..project and .classpath file?
Wayne
Re: problem with subversive [message #178495 is a reply to message #178395] |
Mon, 06 November 2006 02:33 |
Thank you very much for your suggestion!
I've solved this problem yesterday. I use another svn plugin named
'subclipse' which solves my problem. But I still think maybe I've done some
wrong steps when I used 'subversive'.
"Zhang Maosen" <maosen.zhang@alibaba-inc.com> д
FUDForum. Page generated in 0.09399 seconds
