Home » Eclipse Projects » Eclipse Platform » Ant: java.lang.NoClassDefFoundError: org/apache/tools/ant/taskdefs/optional/junit/JUnitTestRunner
Ant: java.lang.NoClassDefFoundError: org/apache/tools/ant/taskdefs/optional/junit/JUnitTestRunner [message #178093] Sat, 10 January 2004 13:30 Go to next message
Originally posted by: cwhite.ic.net
After installing M6, I get these error when trying to run ant build scripts
that include the junit task.
[junit] java.lang.NoClassDefFoundError:
[junit] Exception in thread "main
I checked to see the the ANT classpath includes the optional.jar that comes
with the M6 install. It does.
What is the fixed for this?
Re: Ant: java.lang.NoClassDefFoundError: org/apache/tools/ant/taskdefs/optional/junit/JUnitTestRunne [message #178489 is a reply to message #178093] Mon, 12 January 2004 04:58 Go to previous messageGo to next message
The following might help:select the JRE page (in the wizard that comes
up when launching your script) and select "Run in the same JRE as the
workspace".
Dani
Re: Ant: java.lang.NoClassDefFoundError: org/apache/tools/ant/taskdefs/optional/junit/JUnitTestRunne [message #183088 is a reply to message #178489] Wed, 21 January 2004 15:49 Go to previous messageGo to next message
Originally posted by: jbennett.liquent.com
Daniel Megert wrote:
>> scripts
> workspace".
Is there any way to avoid this error while using an external JDK? I have
to increase the heap size for my ant script, but I still get the
JUnitTestRunner not found error.
jason
Re: Ant: java.lang.NoClassDefFoundError: org/apache/tools/ant/taskdefs/optional/junit/JUnitTestRunne [message #183125 is a reply to message #183088] Wed, 21 January 2004 16:40 Go to previous messageGo to next message
Likely your classpath is not sufficient for the Junit task. If the buildfile
works from the commandline and does not work within Eclipse, please log a
bug report against platform Ant and I will have a look.
Note to increase the heap size when running in the same VM as Eclipse start
eclipse specifying -vmArgs. Something like:
-vmArgs -Xmx450M -Xms250M
HTH
Darins
"Jason Bennett" <jbennett@liquent.com> wrote in message
news:bumohm$pln$1@eclipse.org...
> >> scripts
> > workspace".
> jason
Re: Ant: java.lang.NoClassDefFoundError: org/apache/tools/ant/taskdefs/optional/junit/JUnitTestRunne [message #183139 is a reply to message #183125] Wed, 21 January 2004 17:30 Go to previous messageGo to next message
I managed to get the task to work using the internal VM, by specifying
those types of args. Using the external VM, though, never worked.
I suspect that the optional.jar file isn't being handed off properly to
the external VM, but I have no real way to verify that.
jason
Re: Ant: java.lang.NoClassDefFoundError: org/apache/tools/ant/taskdefs/optional/junit/JUnitTestRunne [message #183175 is a reply to message #183139] Wed, 21 January 2004 17:52 Go to previous messageGo to next message
Can you please log a bug report
Darins
news:bumuem$1v6$1@eclipse.org...
buildfile
a
start
> jason
Re: Ant: java.lang.NoClassDefFoundError: org/apache/tools/ant/taskdefs/optional/junit/JUnitTestRunne [message #183626 is a reply to message #183175] Thu, 22 January 2004 11:18 Go to previous message
Done,thanks for your help.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=50400
jason
Previous Topic:editing XML in eclipse (& not lauch browser!)
Next Topic:building javadoc in build process (*.doc.isv plugins)
Current Time: Thu Nov 27 21:43:59 EST 2025
Powered by FUDForum. Page generated in 0.04623 seconds
