installation problems [message #177699] |
Wed, 15 September 2004 03:53  |
Originally posted by: peter.synobsys.be
! Hi,
I'm getting the following error when I try to startup Elcipse 3.0:
What I find strange is theat the java version posted in the log doesn't
correspond with the current java runtime environment on my pc. I'm now
running version 1.4.2_05
and the sdk1.4.2_04.
The log says I'm running 1.3.1_01 version
Can somebody help me out with this problem?
Peter Lesage
Synobsys
SESSION sep 14, 2004
12:57:35.266 ---------------------------------------------
eclipse.buildId=I200406251208
java.version=1.3.1_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=nl_BE
!ENTRY org.eclipse.osgi sep 14, 2004 12:57:35.266
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.registerEndo rsedXMLParser(Ec
lipseAdaptor.java:272)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSta rt(EclipseAdapto
r.java:253)
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start(SystemB
undleActivator.java:61)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleConte
xtImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(Bu
ndleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleConte
xtImpl.java:937)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(Sta
rtLevelManager.java:553)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLeve
lManager.java:477)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(S
tartLevelManager.java:273)
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevel
Manager.java:243)
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.ja
va:166)
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:425
org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:
216)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
!ENTRY org.eclipse.osgi sep 14, 2004 12:57:35.507
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: org/xml/sax/helpers/DefaultHandler
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginC
onverterImpl.java:552)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginCo
nverterImpl.java:111)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginC
onverterImpl.java:655)
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseB
undleData.java:219)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundl
eData.java:177)
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundle
Data.java:159)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseB
undleData.java:266)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initial
izeNewBundle(DefaultBundleData.java:77)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(De
faultAdaptor.java:451)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(F
ramework.java:746)
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:664)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.j
ava:715)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.j
ava:659)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(Bun
dleContextImpl.java:219)
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarte
r.java:800)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStar
ter.java:429)
222)
!ENTRY org.eclipse.osgi sep 14, 2004 12:57:35.517
!MESSAGE Bundle
initial@reference:file:c:/Prog/eclipse/plugins/org.eclipse.core.runtime_3.0.
0/ [1] was not resolved.
Re: installation problems [message #177755 is a reply to message #177699] |
Wed, 15 September 2004 08:31   |
Originally posted by: manahan.NOSPAM.ca.ibm.com
If you go to the command line and type "java -version" is that correct.
Do you have a jre directory in your eclipse install? eclipse\jre? If so
what is the version of the JRE.
When you look at the installed JRE preferences where does it say your
JAVA_HOME is located?
Peter
Peter lesage wrote:
> ! Hi,
> Best regards,
> Peter Lesage
> Synobsys
> !STACK 0
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> r.java:253)
> at
> at
> xtImpl.java:958)
> at
> at
> xtImpl.java:937)
> at
> at
> lManager.java:477)
> at
> at
> Manager.java:243)
> at
> va:166)
> at
> at
> at
> 216)
> at
> !STACK 1
> at
> at
> at
> at
> undleData.java:219)
> at
> eData.java:177)
> at
> Data.java:159)
> at
> undleData.java:266)
> at
> at
> at
> ramework.java:746)
> at
> at
> ava:715)
> at
> ava:659)
> at
> at
> r.java:800)
> at
> ter.java:429)
> at
> 222)
> at
> !MESSAGE Bundle
Re: installation problems [message #177778 is a reply to message #177755] |
Wed, 15 September 2004 09:00  |
found the solution,
I know remember that in advanced system properties < environment variables
there is a setting for the path with this written in it
C:\oracle\ora92\bin;C:\Program Files\Oracle\jre\1.3.1\bin;C:\Program
Files\Oracle\jre\1.1.8\bin;%SystemRoot%\system32;%SystemRoot %;%SystemRoot%\S
ystem32\Wbem;C:\Program Files\Common Files\Adaptec
Shared\System;C:\Advantage Plex\Versie51\bin;
I removed C:\Program Files\Oracle\jre\1.3.1\bin AND C:\Program
Now eclipse is startin up without any errors and my oracle database is still
working so no harm done.
"Peter Manahan" <manahan@NOSPAM.ca.ibm.com> wrote in message
news:ci9cfs$gk2$1@eclipse.org...
> Peter
> Peter lesage wrote:
> > ! Hi,
> > Best regards,
> > Peter Lesage
> > Synobsys
> > !STACK 0
Method)
> > at
> > at
> > r.java:253)
> > at
> > at
> > xtImpl.java:958)
Method)
> > at
> > at
> > xtImpl.java:937)
> > at
> > at
> > lManager.java:477)
> > at
> > at
> > Manager.java:243)
> > at
> > va:166)
> > at
> > at
> > at
> > 216)
> > at
> > !STACK 1
Source)
Method)
> > at
> > at
> > at
> > at
> > undleData.java:219)
> > at
> > eData.java:177)
> > at
> > Data.java:159)
> > at
> > undleData.java:266)
> > at
> > at
> > at
> > ramework.java:746)
> > at
Method)
> > at
> > ava:715)
> > at
> > ava:659)
> > at
> > at
> > r.java:800)
> > at
> > ter.java:429)
> > at
> > 222)
> > at
> > !MESSAGE Bundle
FUDForum. Page generated in 0.06342 seconds
