| BIRT 2.1 Group By in Table inserts a page break [message #177521] |
Fri, 14 July 2006 01:39  |
Originally posted by: stilkari.gmail.com
I am trying to insert a table with some values in a report. Whenever I am
trying to group the table with one of the fields in the dataset, it is
inserting a page break, while displaying the report in PDF format. All
values are comming in the table, but every new group is going on new page.
I haven't set any page break. If I remove the group by field, then all
values are comming in the table without page break(as expected).
Why the group by is inserting a page break?
Is it a bug in BIRT 2.1?
Does anybody has faced this type of problem?
Thanks in advance.
Santosh
| (Solved) Re: BIRT 2.1 Group By in Table inserts a page break [message #177535 is a reply to message #177521] |
Fri, 14 July 2006 01:58  |
I got answer for my post. To avoid the page break, the "Before" property(
under Page Break") of "Group Details" window, is to be set to "Avoid"
instead of "Auto". After setting the property to "Avoid" it is working as
expected i.e. it is not inserting a page break for each group.
Thanks & regards,
Santosh
FUDForum. Page generated in 0.12335 seconds
