Home » General (non-technical) » Eclipse Foundation » Testing tools used in eclipse build process
Testing tools used in eclipse build process [message #16787] Thu, 10 March 2005 11:39 Go to next message
Hi all, I'm trying to get a handle on the testing procedures used by the
eclipse team (particularly the automated tests that are part of the build
process) - I heard some tidbits at eclipsecon, so I went to look and see
the nuts and bolts, but can't find one good high level view. Is there one
available?
So far I've uncovered the two test applications in the org.eclipse.tests
plugin that use command line params to derive the plugin and classname for
a junit test to run.
I've also found the org.eclipse.core.tests.harness plugin which defines a
couple more application classes and derives its test cases from an
extension point.
Is one of these mechanisms deprecated in favor of the other?
-James
Re: Testing tools used in eclipse build process [message #16790 is a reply to message #16787] Thu, 10 March 2005 22:45 Go to previous message
Originally posted by: pascal.ibm.canada
Please ask this question on the platform newsgroup.
PaScaL
> build process) - I heard some tidbits at eclipsecon, so I went to look
> and see the nuts and bolts, but can't find one good high level view. Is
> there one available?
> for a junit test to run. I've also found the
> org.eclipse.core.tests.harness plugin which defines a couple more
> application classes and derives its test cases from an extension point.
> Thanks
> -James
Previous Topic:IP Evaluation for Libraries: Processes and tools needed?
Next Topic:Help wanted reading and reviewing new articles
Current Time: Thu Jul 17 16:28:34 EDT 2025
Powered by FUDForum. Page generated in 0.28428 seconds
