Home » Modeling » GMF (Graphical Modeling Framework) » BorderItem
BorderItem [message #177290] Fri, 14 March 2008 06:26 Go to next message
I would like to know of there is a way to have borderItem moving around
a node considering the direction of the connection linked to this
borderITem (a port). Is there a class of Router or Anchor which has this
parameter, or do you have any help about where customizing the code (the
node itself, the anchor, the router, the connection ???)
Guillaume
Re: BorderItem [message #177502 is a reply to message #177290] Sun, 16 March 2008 06:24 Go to previous message
Originally posted by: jan.koehnlein.web.de
You should have a look at the BorderItemLocator registered by the parent
edit part. I remember I had to play around with this one, as the
children were not placed the way I defined in the graph model. Don't
know if you can implement the behaviour you want.
Jan
Guillaume Gauffre wrote:
> Guillaume
Previous Topic:how can i create a swimlane?
Next Topic:deployed my gmf plug-in
Current Time: Thu Jul 17 22:26:32 EDT 2025
Powered by FUDForum. Page generated in 1.06815 seconds
