sharing objects between models [message #177149] |
Tue, 12 April 2005 20:51  |
Originally posted by: flsobral.yahoo.com.br
Hello.
I'm working on a case tool using GEF and EMF. I want it to be able to
create as many models as I want and share anything created in one model
with any other model in the same project, giving a different view of the
same object in each model.
For instance:
I have UMLmodel1 and I created the classes Class1 and Class2 with a
association between them. In another model UMLmodel2 located in the same
project as UMLmodel1, I want to be able to use the same Class1 and Class2
with the same features without rewriting it and also be able to choose if
I want to choose the association between them. Any changes mades on a
class in any model should reflect in all models.
Basically something close to Rational Rose, where everything can be shared
between models of the same project.
Can it be done? Any example I should look?
Thanks in advance.
Re: sharing objects between models [message #177345 is a reply to message #177275] |
Wed, 13 April 2005 19:26   |
"Sure. GEF is model-agnostic, so it doesn't care about how you set-up your
model. You can look at the EDiagram example (available from the CVS
repository), which allows you to graphically create ecore files. EMF
allows
one ecore file to refer to packages, classes in other ecore files, and the
example provides that support as well."
I tought about that, but it leads to consistency problems if the user
tries to edit 2 ediagrams at same time.
Is there another way to do this that doesn't have this problem or to
disallow the user to open more than one edit window for the same type of
file? Maybe save and close the current before openning a new one.
Thanks.
Re: sharing objects between models [message #177655 is a reply to message #177392] |
Thu, 14 April 2005 19:33   |
"If all open editors refer to the same instance of the model, you won't
have
any consistency problems. As soon as one editor triggers a change, it will
be updated in all other editors as well."
But that's not what happens in the EDiagram example. If I open 2 ediagram
editors that share the same ecore, any changes made in the first one are
not updated in the second ediagram editor. Besides that, if I save new
changes in the second another editor, the previous changes made on the
first one will be lost. After this point, every time I save one ediagram I
will be losing the changes made in the other ediagram.
Thanks again.
Re: sharing objects between models [message #177711 is a reply to message #177655] |
Thu, 14 April 2005 21:26   |
Still about the EDiagram example...
The DiagramImpl has a reference to the ecore file, but I didn't find where
this reference is used and the information in the ecore file retrieved to
be used with the information stored in the ediagram file.
I also didn't understand where the variable rsrcSet is changed, because
when it is created in setInput it has only a reference to the ediagram
file, but when the method doSave is used it also has a reference to ecore
file.
Thanks.
Re: sharing objects between models [message #177980 is a reply to message #177692] |
Fri, 15 April 2005 21:40   |
"That's simply because the EDiagram editors didn't share the in-memory
model.
If you do, you'll be fine. In fact, I've just updated EDiagram editor to
do
that. Catch up."
You forgot to implement the method isDirty.
Re: sharing objects between models [message #178325 is a reply to message #177988] |
Tue, 19 April 2005 20:11   |
I found something that may be a bug.
When you delete a ediagram from a project and create a new ediagram with
the same name as the one deleted and in the same project, it will come
with the same elements as the one deleted.
Should it work that way?
Re: sharing objects between models [message #180534 is a reply to message #178347] |
Fri, 06 May 2005 21:34   |
Create a new ediagram named "a" associated with a new ecore named "a",
make a new class in this ediagram and save.
Now close both windows and delete both files.
Create a new ediagram named "a" associated with a new ecore named "b" and
the same class will still be there on the ediagram, but not in the new
ecore.
If you create a new ediagram named "b" associated with a new ecore named
"a" this won't happen. Both will be empty.
This seems to be a bug for me, I expected a new ediagram editor always to
be empty.
FUDForum. Page generated in 4.61942 seconds
