java.lang.OutOfMemoryError [message #177055] |
Fri, 27 October 2006 16:07 |
Originally posted by: fariano2003.yahoo.com
After running my code, I end up with java.lang.OutOfMemoryError and some
of the objects do not show on the screen untill I stretch the window using
the mouse. I do not know if this is a java issue or an Eclipse issue. How
can this problem be investigated/resolved?
Re: java.lang.OutOfMemoryError [message #177070 is a reply to message #177055] |
Fri, 27 October 2006 16:28 |
> using the mouse. I do not know if this is a java issue or an Eclipse
> issue. How can this problem be investigated/resolved?
> Thanks
What kind of application is it? Is it Swing-based or Eclipse RCP? Is
there a stack trace?
Did you try bumping up the amount of memory available to Java?
Wayne
Re: java.lang.OutOfMemoryError [message #177094 is a reply to message #177070] |
Fri, 27 October 2006 16:52 |
Wayne,
I am using Swing-based Eclipse and I am not familiar with stack trace; I
am new to java. How do I bump up amount of memory to java? Can it be done
through Eclipse?
Re: java.lang.OutOfMemoryError [message #177118 is a reply to message #177094] |
Fri, 27 October 2006 17:19 |
Fariano wrote:
> Wayne,
Is there any output in the Eclipse console?
> done through Eclipse?
For information about command line options for Java (on Windows), see:
http://java.sun.com/j2se/1.4.2/docs/tooldocs/windows/java.ht ml
In Eclipse, open the launch configuration for your application ("Run >
Run..."), switch to the "Arguments" tab, and enter -Xmx256MB (or
something like that) into the "VM Arguments" box.
Wayne
Re: java.lang.OutOfMemoryError [message #177161 is a reply to message #177118] |
Fri, 27 October 2006 19:31 |
The console shows the OutOfMemory error message (and a list of files it
has problem with). There is a good chance that the problem is the heap
memory. I will change the size and hopefully it would work. Thanks for
the help Wayne.
FUDForum. Page generated in 0.07873 seconds
