Can't unzip eclipse-SDK-3.2.1-win32.zip! [message #177046] |
Fri, 27 October 2006 15:26 |
Originally posted by: james.telestial.org
I am having problems unzipping eclipse-SDK-3.2.1-win32.zip. I'm using
WinZip and it keeps complaining that some of the zipped files are in use
so can't extract them.
Has anyone else had this / know what the solution is?
James
Re: Can't unzip eclipse-SDK-3.2.1-win32.zip! [message #177063 is a reply to message #177046] |
Fri, 27 October 2006 16:26 |
> James
I've been having trouble using the WinXP ZIP support. It seems to work
fine with WinZIP 9.0. What version of WinZIP are you using?
Wayne
Re: Can't unzip eclipse-SDK-3.2.1-win32.zip! [message #177417 is a reply to message #177046] |
Mon, 30 October 2006 15:05 |
That sounds to me like perhaps your Eclipse is running and you are
trying to extract the new version on top of it.
Note that it will not work to extract a new version on top of an old one
- use the Update Manager or install the new one to a different location.
Hope this helps,
Eric
FUDForum. Page generated in 0.08259 seconds
