Home » Archived » Riena » HowTo build an Equinox-Riena-EasyBeans-OSGI-Server
HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #16718] Mon, 17 November 2008 09:58 Go to next message
Originally posted by: ekkehard.gentz-software.de
just published a new entry of my blog series
HowTo build an Equinox-Riena-EasyBeans-OSGI-Server:
http://ekkes-corner.blogspot.com/2008/11/howto-build-osgi-en terprise-server-ejb3.html
now following parts of this blog series are available:
1. Introduction
5. Entity and EJB Bundles
6. Easybeans EJB3 Container
following will follow:
2. Overview
3. Installation (Equinox, Riena, EasyBeans)
4. Server Start (Start-Level, Start-Order)
7. EasybeansServiceTracker
8. Riena Remote Services
9. Configuration, Logging,...
if you follow this blog series at the end you'll get an OpenSource OSGI
Server combining Riena and EasyBeans under Equinox
ekke
blog in english: http://ekkes-corner.org
blog in german: http://ekkes-ecke.org
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #16728 is a reply to message #16718] Sat, 22 November 2008 11:33 Go to previous messageGo to next message
Ekke, Are you planning to show examples of Riena UI too? I do RCP
applications and an wondering if someone in this group is going to talk
UI also.
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #17499 is a reply to message #16728] Sat, 22 November 2008 14:14 Go to previous messageGo to next message
> UI also.
yes !
But I'm using Riena UI only partly - not the strict UI - only Views with
Ridgets / Markers / Validation in a RCP app communicating with the
server thru Riena Remote Services and also using Riena
ObjectTransactions to transfer deltas of changed entity attributes only
....and we just started a subproject (redView - Riena EMF Dynamic View)
where we generate the Riena Views and create the View dynamically
....please expect some weeks until Client - UI - Examples will come
and before you ask: at the moment there's no source code published -
but will come soon (Open Source EPL)
ekke
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #17502 is a reply to message #16728] Sun, 23 November 2008 08:49 Go to previous messageGo to next message
Hi Vel,
did you look at the UI samples, the UI Snippets that are already available ?
Have you concret questions that I could help you with ?
regards
christian
> UI also.
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #17554 is a reply to message #17499] Mon, 24 November 2008 11:15 Go to previous messageGo to next message
Thanks Ekke. I have a suggestion for you.
I am sure you might be comfortable with SWT and JFace classes. For any
beginner or an expert, mastering layout is a huge task. If you look at
o.e.pde.ui or o.e.jdt.ui, IBM folks have created nice abstract classes
to extract the layout (they are internal to pde and jdt plugins). Thus,
the classes of wizard pages and editor pages concentrate on 'actual
stuff' rather laying out the controls.
This may be too early for you to give best practices on ridgets but we
need to explore the possibilities.
Do you use different themes in your Firefox browser? It would be fun if
Riena allows us to download a theme class from this site and use as
such. Wouldn't it be awesome?
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #17567 is a reply to message #17554] Mon, 24 November 2008 17:26 Go to previous messageGo to next message
Hi Vel,
actually ridgets dont deal with layout. Riena still uses the regular widgets and all
the tools that are there to do the layout. Ridgets are a wrapper to widgets and meant
to ease and abstract their usage.
Can you explain how firefox themes relate to Riena. Indeed Riena has something like Themes
and look and feel for SWT but it is not the same thing firefox offers.
Maybe you can clarify your intention with themes.
- christian
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #17606 is a reply to message #17567] Thu, 27 November 2008 11:27 Go to previous messageGo to next message
Sure Christian.
I am a UI fan. I love colors and the arrangements of controls in
Eclipse. I never bothered to open Eclipse source code until I started
building a relatively full-fledged application an year back. o.e.pde.ui
was my target. I still refer it for better usage of JFace viewers.
Coming to Firefox themes, I am sure you will be using Firefox and
Thunderbird. Both these applications have themes that can be downloaded
from mozilla.com. As you download a theme and install, the new theme
plugs seamlessly into the application.
I read about Riena themes and am going to try it. I want to explore if
this possible in the final application. We change the editor font in
Preferences. In a similar, can we give the user a way to choose a
pre-packaged Riena theme using a preference? Your EclipseCon ppt shows
two examples for new RCP appearance. Since the possibilities are
endless, I asked if theme can be put into the application at runtime. Am
I asking for more :) ?
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #17620 is a reply to message #17606] Fri, 28 November 2008 05:24 Go to previous message
Vel schrieb:
> Sure Christian.
You can plugin Themes at runtime but only at starttime at this point in time I believe. But you can
certainly switch Thema without changing your application code.
However the EclipseCon presentations only contains UI-Visions which we had at the that time which was
based on a pre-Riena application based on Swing. Swing quite naturally comes with Themes.
Riena now also has Themes for SWT and you can see a good example for them in this presentation
http://www.eclipsecon.org/summiteurope2008/sessions?id=39 (slide 24) so that is changing color, font, moving
logos navigation and things like that without touching or recompiling the code just by supplying a differnt
system property at start.
Beyond that you can also modify the "Look". We have yet not alternate Look implemented but that would include
having different renders for everything navigation (on the left) like ModuleGroup, Module, Submodule and also for the
top SubApplication switcher and top bar.
any more feedback questions, let me know
christian
p.s. the riena.example.app has two launch files for the different themes
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #577005 is a reply to message #16718] Sat, 22 November 2008 11:33 Go to previous message
UI also.
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #577066 is a reply to message #16728] Sat, 22 November 2008 14:14 Go to previous message
> UI also.
yes !
ekke
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #577087 is a reply to message #16728] Sun, 23 November 2008 08:49 Go to previous message
Hi Vel,
regards
christian
> UI also.
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #577175 is a reply to message #17499] Mon, 24 November 2008 11:15 Go to previous message
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #577189 is a reply to message #17554] Mon, 24 November 2008 17:26 Go to previous message
Hi Vel,
- christian
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #577255 is a reply to message #17567] Thu, 27 November 2008 11:27 Go to previous message
Sure Christian.
Re: HowTo build an Equinox-Riena-EasyBeans-OSGI-Server [message #577275 is a reply to message #17606] Fri, 28 November 2008 05:24 Go to previous message
Vel schrieb:
> Sure Christian.
christian
Previous Topic:Riena Webinary 26.Nov 2008
Next Topic:Sessions about Riena at EclipseCon
Current Time: Thu Jul 17 22:48:36 EDT 2025
Powered by FUDForum. Page generated in 0.30516 seconds
