Home » Modeling » GMF (Graphical Modeling Framework) » Absolute position of a Point
Absolute position of a Point [message #176769] Wed, 12 March 2008 06:10 Go to next message
Hi all,
I just begin to work with draw2d.geometry and I need some help:
In a sequence diagram, I know the relative position of a Point doing this:
GraphConnector connector = (GraphConnector) ((GraphEdge)
childElement).getAnchor().get(numanchor);
org.eclipse.draw2d.geometry.Point pos = new Point(connector.getPosition());
I would like to know the absolute position of this point in the diagram.
Thanks for your help.
Emilien
Re: Absolute position of a Point [message #176883 is a reply to message #176769] Wed, 12 March 2008 10:56 Go to previous messageGo to next message
Hi Emilien,
IFigure defines methods translateToAbsolute(Translatable) and
translateToRelative(Translatable).
Translating a point to absolute coordinates should be easy if you know
the figure whose coordinate system in used by your point. Typically it
takes several guesses to get the correct transformation :)
Boris
Emilien Perico wrote:
> Hi all,
> Emilien
Re: Absolute position of a Point [message #177729 is a reply to message #176769] Mon, 17 March 2008 13:10 Go to previous message
Originally posted by: 5d5.mail.ru
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. draw2d.doc.isv/guide/coordinates.html
> Hi all,
> Emilien
Previous Topic:Label disappears
Next Topic:Set default position of node at creation time
Current Time: Sat Jul 26 18:01:39 EDT 2025
Powered by FUDForum. Page generated in 0.03270 seconds
