Moving a Project to another Machine [message #176679] |
Mon, 06 September 2004 06:31  |
Originally posted by: dummy.dummy.net
What is the best way to move a project from one workspace on
machine A to another workspace on machine B (using Eclipse 3) ?
I searched in the doc, but didn't find a topic about this issue.
Thanks in advance for your help.
Zaack
Re: Moving a Project to another Machine [message #176712 is a reply to message #176688] |
Mon, 06 September 2004 07:58  |
I just wanted to add to that, that if you have linux AND windows
computers, sharing a project among several linux AND windows machines by
means of sharing the underlying filesystem is a very bad idea.
It is very likely it will mess your files with CR/LF problems.
Hope this helps,
Jean
Horváth, Csaba wrote:
> If you don't use absolute paths (e.g in the classpath) you can simply copy
> your project directory into another workspace, start Eclipse using the
> target workspace and use File>Import>Existing project into workspace.
> (if you use a version control system then checking all files in and check
> out the whole project in the another workspace is a better way I think)
> HTH,
> Csaba
> "Zaack" <dummy@dummy.net> wrote in message news:chhe3b$mvh$1@eclipse.org...
>>Hello,
>>Zaack
FUDForum. Page generated in 0.09700 seconds
