Eclipse Clean build removing hidden files [message #176675] |
Thu, 26 October 2006 05:49  |
Originally posted by: rydtoft.hotmail.com
Hi group,
I use Eclipse and svn. Eclipse builds into a /classes folder which is also
in the svn repository and as such has a .svn sub folder in /classes/.svn
When I use the Clean build option in Eclipse (i.e. Project -> Clean) it
COMPLETELY wipes my /classes folder INCLUDING removing the .svn folder.
This is a problem as the .svn folder should never be deleted.
Is there a way to tell Eclipse to ignore certain folders and/or files when
using the Project -> Clean command?
Cheers Michael
Re: Eclipse Clean build removing hidden files [message #177410 is a reply to message #176675] |
Mon, 30 October 2006 10:02  |
Originally posted by: eclipse4.rizzoweb.com
Michael Rydtoft wrote:
> Hi group,
> also in the svn repository and as such has a .svn sub folder in
> /classes/.svn
> when using the Project -> Clean command?
I agree with the earlier response that it is not generally a good idea
to include derived content (such as .class files) in the repository. It
goes against what is a widely accepted "best practice" of the
Configuration Management/SCM world.
Having said that, you can probably get things set up to leave the files
alone. There is a Preference setting (under Java > Compiler > Building)
to disable the cleaning of the output directory, which you could use.
The ramification of doing so is that a "clean" build is no longer such -
it will leave behind old files.
You could also set up Eclipse to build into a different directory and
then use a small Ant script to copy the .class files into the directory
that is checked in to SVN.
Still, I would re-think the idea of having the compile output location
be checked in, unless there is some peculiar, specific reason your
project needs it that way.
Hope this helps,
Eric
FUDForum. Page generated in 0.38481 seconds
