Getting some parsing exceptions..... [message #16696] |
Fri, 27 January 2006 06:37  |
Can you help why I am getting these type of errors while evaluating
some
Ocl expressions?....like-
Expression : self.attribute->product(self.attribute)
Error : org.eclipse.emf.ocl.helper.OclParsingException[1]:
Collection type conformance failure: (null).(product)
Please fix your code to add using
EClass.getEStructuralFeatures()
instead of EClass.getEReferences()
Expression : Set{self.attribute.name}->product(Set{self.attribute.name})
Error : org.eclipse.emf.ocl.helper.OclParsingException[1]: Collection
type conformance failure: (Set(null)).(product)
instead of EClass.getEAttributes()
Expression : Set{self.attribute}->product(Set{self.attribute})
Collection type conformance failure: (Set(null)).(product)
Thanks and Regards,
Shrawanika
Re: Getting some parsing exceptions..... [message #20007 is a reply to message #19882] |
Thu, 02 February 2006 09:09   |
Hi, Shrawanika,
If "attribute" is a DataType with multiplicity many, then this should
certainly work. Even if it was a scalar multiplicity, it should be coerced
to a Set type automatically. Looks like a bug, if you care to raise it.
Christian
Shrawanika wrote:
> Hi Christian,
> No, the "attribute" feature has type defined (the Type is not
> "null").
> I instantiated UML 1.3 Metamodel. And the attributes have DataType as
> their Object Type.
> Then, what can be the possible reason for this error:
> Thanks and Regards,
> Shrawanika
Re: Getting some parsing exceptions..... [message #564365 is a reply to message #16696] |
Fri, 27 January 2006 07:09  |
Shrawanika,
This should be changed. Please open a bugzilla to make sure it does.
Shrawanika wrote:
> evaluating some Ocl expressions?....like-
> Expression : self.attribute->product(self.attribute) Error :
> Please fix your code to add using EClass.getEStructuralFeatures()
> Collection
> Thanks and Regards,
> Shrawanika
Re: Getting some parsing exceptions..... [message #564422 is a reply to message #16696] |
Fri, 27 January 2006 08:17  |
Hi, Shrawanika,
It appears from the OclParsingException that the "attribute" feature does
not have a type (the type is "null"). Is that the case?
Regarding the syserrs about Eclass.getEStructuralFeatures(), yes, please
open a bugzilla.
Christian
Shrawanika wrote:
> some
> Collection
> Thanks and Regards,
> Shrawanika
Re: Getting some parsing exceptions..... [message #565357 is a reply to message #16735] |
Thu, 02 February 2006 03:51  |
Hi Christian,
No, the "attribute" feature has type defined (the Type is not "null").
their Object Type.
Thanks and Regards,
Shrawanika
Re: Getting some parsing exceptions..... [message #565446 is a reply to message #19882] |
Hi, Shrawanika,
Christian
Shrawanika wrote:
> Hi Christian,
> "null").
> their Object Type.
> Thanks and Regards,
> Shrawanika
FUDForum. Page generated in 0.30092 seconds
