Home » Eclipse Projects » DSDP - Target Management » Many Save Conflicts
Many Save Conflicts [message #16684] Mon, 10 December 2007 19:14 Go to next message
Originally posted by: j.craig.aggiemail.usu.edu
Using RSE to edit remote files, I've been getting "Save Conflict" dialogs
on nearly every save. It is asking if I want to "Replace contents of
editor with remote file", "Overwrite the remote file", or "Save the
contents of the editor to a different remote file". I have been
overwriting because I know no one else is editing these files.
I haven't seen this happen until I recently upgraded to TM 2.0.2.
Is this a bug, or is there some other issue that may be at work here?
thanks,
--Jason
Re: Many Save Conflicts [message #16734 is a reply to message #16684] Tue, 11 December 2007 13:25 Go to previous messageGo to next message
Hello Jason,
this sounds like a bug - please file a bugzilla entry for it.
Please include information like
- What connection type do you use (ssh, dstore, ...)
- What kind of remote system?
- Do you use RSE directly or through the EFS integration?
It looks like RSE doesn't get the timestamp of the remote file
right. It might help comparing the timestamp in the RSE properties
view against the actual timestamp as seen when doing "ls -l"
in a remote shell against the timestamp of the cached file in
RemoteSystemsTempFiles/...
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> dialogs on nearly every save. It is asking if I want to "Replace
> contents of editor with remote file", "Overwrite the remote file", or
> "Save the contents of the editor to a different remote file". I have
> been overwriting because I know no one else is editing these files.
> thanks,
> --Jason
Re: Many Save Conflicts [message #16739 is a reply to message #16734] Tue, 11 December 2007 13:37 Go to previous messageGo to next message
Actually,
when you have some EFS links open, your bug might be related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205822
Martin Oberhuber
Re: Many Save Conflicts [message #16744 is a reply to message #16739] Tue, 11 December 2007 17:15 Go to previous messageGo to next message
I'm using the RSE itself to browse a Linux system with FTP for a file, and
then double-clicking it to edit it remotely. This isn't using EFS, right?
The file modification times show up the same in the RSE properties and
with ls -l.
--Jason
Re: Many Save Conflicts [message #17560 is a reply to message #16744] Tue, 18 December 2007 04:00 Go to previous message
Could you please file a bug for this on bugzilla?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Target%2 0Management&version=unspecified&component=RSE
Thanks!
> and then double-clicking it to edit it remotely. This isn't using EFS,
> right? The file modification times show up the same in the RSE
> properties and with ls -l.
> --Jason
Martin Oberhuber
Wind River Systems, Inc.
Re: Many Save Conflicts [message #571300 is a reply to message #16684] Tue, 11 December 2007 13:25 Go to previous message
Hello Jason,
Martin Oberhuber
> thanks,
> --Jason
Re: Many Save Conflicts [message #571312 is a reply to message #16734] Tue, 11 December 2007 13:37 Go to previous message
Actually,
Martin Oberhuber
Re: Many Save Conflicts [message #571397 is a reply to message #16739] Tue, 11 December 2007 17:15 Go to previous message
with ls -l.
--Jason
Re: Many Save Conflicts [message #571537 is a reply to message #16744] Tue, 18 December 2007 04:00 Go to previous message
Thanks!
> --Jason
Martin Oberhuber
Previous Topic:Easy Install Question
Next Topic:Management of WindowsCE filesystems
Current Time: Tue Jul 15 04:17:00 EDT 2025
Powered by FUDForum. Page generated in 0.11213 seconds
